OTL for HeaPhone
hello ,
good day to all 😉
me first build to OTL ...
4 day for build , very good , one test
hello ,
me again ...
me headphone for good pleasure 😀
so look is 🙄
Lem DH-1005L - 2 x 300 Ohms
not problem for me headphone , me tested " Queen , Scorpions , AC/DC " 😀
Nice build !
Many OTL headphone amp have an high output impedance which make them not sounding very good with low impedance cans such as Grado (fostex, denon, audio-technica ...).
Beyerdynamic 600ohms, Sennheiser 300-600omhs & "old" AKG 400-600ohms or which where designed with 110ohms output impedance in mind (k701) are far more appropriate in that usage.
Bose headphones are highly NOT well regarded among headphones fan...
Nice build !
lol , me crazy , so build ...build ... very good passion to use old tube 😀
many thank 😉
P = V²/R, and not V²/R²
since V=I*R, so I=V/R and P=V*I, which makes P=(U*U)/R
Assuming 'crete at crete' means peak to peak, 15Vpp = 5,3Vrms. So P=5.3²/16 = 1,7Wrms into 16 ohms(!) That's impossible with your given schematic.
Are you sure your probes aren't set at 10x while the scope presumes 1x??
Because that would make 1,5Vpp = 0,53Vrms. P=0,53²/16 = 17,5mWrms. Now that's a number that makes a lot more sense.
Since gain is quite high, you'll probably feeding the ECC82's grid with about 0.3Vpp. Anything more and distortion will be much too great.
hello ,
okey , i me crazy for bad calculate 🙁 .
so calibrate is 0.5 V for division , no possible 15 V , no no , 1.5 V ... , pfff me escuse to not re looking me calculate 🙄
so good appréciate me build :cheers:
