Nothing wrong with the LM317. The capacitor on the output pin, blocks all of the 'noise'.
I already know all about matching to output capacitor -esr
And selecting capacitor Cadj in the lm317
I Want recommendation
Regulator in the same configuration of LM317
Regardless of price that better 🙂
I'm probably going to change the regulator lm317
to
LM1085
For my project on the ARCAM FMJ PRE
To create a voltage of 5 volts positive
I need resistors
121Ohm
And
365Ohm
Currently in the ARCAM PRE
the smd resistor ar
470 OHM resistor ( R1)
1220 ohm and 220 ohm (R2)
So my plan
Replace the (R1) to 121 ohm
and
(R2) to 121ohm+243 ohm
the output capacitor and the adjast pin cap i chenge to 22uf
KEMET - T356K226K035AT - CAP, TANT, 22UF, 35V, RAD
and the input smd 100nf capacitor
i change to 10 uf rubycon ZLH CAP
to
LM1085
I need resistors
121Ohm
And
365Ohm
the smd resistor ar
So my plan
and
- Design & Build
- Parts
- Modern replacement to Regulator LM317 With low noise ?
