OP Amp oscillator sine wave too sharp
I want to make a better sine wave than the below circuit produces. I know very little about OP amp design.... a capacitor or an inductor somewhere, or a whole different circuit? Or chip? Frequency range and amplitude are fine, but I can hear a "slapping" that I think are the points on the wave? Thanks!
That's the point: your circuit by design doesn't make a sine wave. If you really want something that comes close to a sine wave, you need to throw away your circuit and build something else, for example one of those TI circuits (though some of them don't have a well-defined amplitude).
On the other hand, if you just want a smooth waveform without sharp corners, it may be sufficient to just add a capacitor from pin 5 to ground. Try something of the order of 1 uF, depending on how smooth it needs to be.
Perhaps the change in bias voltage is causing your amplifier to become unstable. It may be starting to oscillate on one of the peaks of the triangular waveform.
Marcel - You rock! I knew I went to the right forum.... ended up with an .047uF to keep amplitude (turns out it is a tradeoff). No more slap! (at the risk of being booted, it's for a tube amp - all I'm gonna say...). Needed some pure solid-state geekdom. Thanks again!
Michael Bean has the correct solution...diode wave-shaping...frequency independent.
Used by signal generator IC's for many years.
A capacitor will filter harmonics but will change the amplitude with frequency...did you say tradeoff?
Thanks but I don't need a real sine wave, just a smooth cyclic modulation signal - which I now have. Don't want to make it too complicated and time consuming, but I do appreciate the information. A while back I needed to convert a square wave to a 0-5 VDC signal, and spent considerable time working with hex converters, VFOs and other devices. I have lots of other things I want to play with. Thanks again!
just use your DAP - Sansa Clip, iPod, whatever - can make .wav file of any wave you can write the math for in a number of free sw
-80 dB THD is pretty easy for most of these today
and it is battery powered so no gnd loops
