JVC Laser A little more juice? How?
Hello!
Last week this laser died after slowly hardly getting to read any more cd-s!
How can I give it more power? I have a multi meter that has a 20k Ohm scale as well! Pics atached!
Signs that it shows when cd's inserted: one spin 00:00:00 on display numbers read!
Stereo system model: XR-UXD99RGD
Thank you!
Here are the pics!
Any measurements with the meter, values and spots to apply probes for measurements so that I know that I have hit the right value? I have had the laser disassembled out of it's assemblage and cleaned the prism, under lens, surface lens and all that i could reach on the inside!
Ok did the clockwise spin! It reads CD's plays CD's but it puts a friction sound through the speakers when playing the disk like the lens would friction the disc! is it too much of a spin or too little?
seems too much... maybe... I have no idea how much you increased the laser output already. Try decreasing the laser output a little and see if there's any difference.
It could be that you did something else while disassembling -> reassembling the mechanism that maybe causes the hissing....?
