I'll go out on a limb and state the QUAD is the lowest distortion speaker ever made.
Thx-RNMarsh
Has not this fetish for burn in come from burn in testing that most life/mission critical equipment has to go through, it is a part of the specification for all class 3 based electronics I have worked on, and is to stress the whole assembly at the specified operating conditions including often severe changes of temperature...
Quite a bit lower...maybe a 100 times lower than 1%.
-RNM
Who are you kidding, you guys don't listen at "Quad" levels especially in the bass. Look I'm not talking about digital hash. Component non-linearities are inherently low order and HAVE to appear at the same frequencies as each other. The same argument that lots of them add up to audibility, could be used to claim removing any one of them is inaudible. You can't have it both ways i.e. removing one nasty magnetic resistor lifts a dozen "veils".
Yes it is related to the well-known (to some) 'bath tub' failure curve. Typically, electronics fail either very early (infant mortality) or very late in their life time (old age). So with burn in you want to weed out the infant mortality failings, which makes the rest work reliably for many, many years.
Has nothing to do with (sound) quality.
One thing I do find curious (or maybe not) is why burn-in always improves stuff, never makes it worse...
Jan
I find that advanced understanding of some topics of physics is VERY useful in making better audio products.
Please buy a copy of Forwood's book, or go to your local technical library and read the pages I referenced, then we will have something to discuss.
Preventing the SEM beam from modifying the surface being examined is a standard problem John. Anybody can zap the surface during viewing. It's the finess that prevents surface changes.
You claiming some magical process after reading some bog standard SEM methodology issues is tired and old.
You tried this schtick many years ago, it was shot down then as well.
jn
Here are two pages. The second page states that the mechanism is NOT due to the Electron microscope, so there! '-)
So, how does he prove it's not induced by beam heating?
How does one take a picture of an object using a beam that can change the object, yet claim that the picture of a change was not caused by the beam being used??
Are you always that gullible John??😉
If you really want to look at surface energy stuff, look up tin whiskers.
That'll fry your brain..
That, and toyota unintended acceleration.
jn
