I have been comparing these DACs.
PCM1704:
Amanero USB + diyinhk USB isolator
FIFO + FIFO Isolator
Dual XO
Crystek CCHD957 XO
Universal I2S to PCM converter
PCM1704 NOS DAC
2 x LME49710 as IV converter
Buffalo III:
Placid PSU
Placid BP PSU
Amanero USB + diynhk USB isolator
Buffalo III DAC
Legato 3 I/V
Three times, in different days with three different persons, PCM1704 was better in resolution, better highs and bass, with wide soundstage and more natural and involving sound.
I know, ES9018 can be configured in multiple ways, and this Buffalo III too, but with this configuration I (and others) clearly preffer pcm1704 over Buffalo.
(BIII pic is not up to date: diyink isolator is missing.)
This is only my own impressions
PCM1704:
Dual XO
Crystek CCHD957 XO
PCM1704 NOS DAC
Buffalo III:
Placid PSU
Placid BP PSU
Buffalo III DAC
Legato 3 I/V
I have also the two DACs the only difference is that my PCM1704 don't have FIFO + FIFO isolator because cost a lot of money and I don't know it's perfomance. You are right PCM1704 is better the only thing is can't play DSD files like the Sabre. Have you tried to use the PCM1704 with the Legato & the BIII with the LME49710? Could you post the schematic used PCM1704 & LME49710?
Try PCM1704 with SEN IV original version.
You can make one up in no time, especially if you have 2SK389 or LSK389.
Ask those who tried.
http://www.diyaudio.com/forums/digi...minimalistic-iv-converter-13.html#post2952599
http://www.diyaudio.com/forums/digi...minimalistic-iv-converter-17.html#post3029604
Patrick
Patrick
My setup I believe is the most simple anybody can imagine.
I/V converter has a BW of 100 kHz (-1dB) in my sims.
Patrick
Thanks EUVL.
Yes, I have tried your Sen IV with regulated PSU and with batteries but I AM UNABLE to manage NOISE to acceptable levels.
Congratulations for the new step! I keep up the Buffalo 32S and my analog source.
Best regards
JH
José Humberto!
Cool violin!
Many thanks Luis.
Thanks EUVL.
Noise powered with batteries😕
Hi Luis & Merlin el mago,
Can I ask you if you have tried to play 384 kHz or 192 kHz files on your PCM1704 DACs?
Jesper
Jesper
Jesper
I could play up to 192 kHz.
maybe the FIFO make a lot of difference between the 2 config ?
I mean, I m using a Vanity 93 fifo in my oppo and i can say that gives difference when using just an ES9023, directly from oppo or from the vanity...?
any chance you could update us on a test without the fifo, just to make sure pcm is still a killer 🙂
I'm not sure, but in these days I'm testing another setup with a very simpler DAC, pcm1704 based, without FIFO and NOS mode.
This DAC is a simple Shift Register and Reclocking, and yes, it still sounds better when compared to Buffalo III.
On the other hand, PSU's are by far better in Buffalo that mine, and Legato or ivy3 I believe are better that my simple I/V converter too.
I will try to do a direct comparison between pcm1704 with and without FIFO if possible.
The non FIFO version has an Amanero interface in Slave mode with Crystek CCHD-957 XO's, and I'm wondering if this approach is better than FIFO. At the moment it seems to me that the two are very similar and are very close.
LuisMCP, try to measure both DACs to check if your setup does not have problem.
You can use either:
- RightMark Audio Analyzer - http://audio.rightmark.org/
- ARTA - ARTA Software
You'll find more info about measurement in their manuals.
The better is not always truer...
You can use either:
Nice setup, though I would shorten the cable between I2S-PCM and DAC board or use u-fl cables.The non FIFO version has an Amanero interface in Slave mode with Crystek CCHD-957 XO's, and I'm wondering if this approach is better than FIFO. At the moment it seems to me that the two are very similar and are very close.
How do you select between the two XOs when Amanero is in Slave mode - are you using Ian's clock board for this, somehow? IMO FIFO vs. Amanero in slave should sound pretty close as Amanero is async.
- Digital Source
- PCM1704 NOS vs Buffalo III
