★★ Free PCB for JLH 2005 Class-A Amplifier
You MUST adjust the pots so that the output is near 0V before connecting the speakers!!! adjust VT3 first, then VT2 and VT1.
Hi
A friend and i just build a set .
His a faster builder than i am and he send me a sms;"DO NOT CONNECT TO POWER YET
SOMETHING IS WRONG,BURNED ALL MY BD139 AND 4 MJ15003!!!"
We checked his boards against mine and the diagram,all just as the doctor ordered.
Components;right values,right placed and orientated,No shorts,no Discontinuity.
Newer the less,my boards acted exatly the same as his.ARRRGG!!!
The bd139 blows after a few seconds,taking the mj15003 with it !???
Whats wrong?
What should i check ?
Is there a startup position of the potmeters,BEFORE power is applied?
Getting tired and annoyed.
Jan
Hi Siliconray,
I am interested to use this amp. I will be using this amp for powering the High frequencies and mid range drivers respectively in my stereo active amplifier system. Let me know if this amp is worth having for my type of set up.
let me know these queries as mentioned below-
1. Do you provide assemble kit?
2. Which transistors you suggest for High frequencies
3. Which transistors you advise for Mid range frequencies?
4. What other kits are required for making a complete stereo system? i mean PSU if any..
5. Give me Heat sink dimension for this class A amp.
6. Do you ship to India?
Samrat
Yes we provide assembly kit. MJ15003 works excellent for both high and mid range frequency. this PSU is highly recommended:
Hi-End Power supply board with speaker protecting - Boards | Kits | Components | Modules | Tools
there's a newer version for this PSU recently, looks different.
200x150x50mm heatsink is suggested for each MJ15003
Yes we ship to India.
Hi
As stated in my last post,speakers not connected,input shorted.
No chance to measure or regulate anything,the bd130 blows instantly when power is applied ?
Faulty bd139 ? all 4 ?,I dont think so ! but then there is another post here #63,same problem ? Shorted bd139 !
It seems his worked with just a replacement.
Jan
Thank you sooooooo much Siliconray for this PCB and your excellent site !! :deer:
A quick question, is this transformer OK for this project?
ebay.com/itm/220V-200W-R-Core-Transformer-Output-20V-20V-/121189176316
:smash:
Hi everyone,
Can someone please explain the difference to me if I use a 60W transformer or a 200W transformer?
With the 60W, will I get lower volume on my speakers?
My speakers are quite small and specified at "nominal impedance 8 ohm" and "max power handling 50W".
..........With the 60W, will I get lower volume on my speakers?...............
The operator and how far he/she adjusts the volume control determines the sound output coming from the speakers.
A sensible operator does not overload the speaker, nor do they overload the amplifier.
The Maximum volume before these two overload conditions is determined by the speakers' abilities and the amplifier's abilities.
The amplifier transformer Vac rating determines the the voltage supplied to the amplifier and that determines the maximum output from the amplifier.
VA of itself does not determine maximum output voltage/power.
Thanks.
I'm still lost though. The PCB says "+-18V to +-25V" at the top, then at the right side of the PCB it says "+22" and "-22".
http://www.siliconray.com/media/cat...525d08d6e5fb8d27136e95/j/l/jlh-2005-pcb_1.jpg
So should I get a transformer that is from 9V+9V to 12.5V+12.5V, or should I get a transformer that is 22V+22V?
I noticed "speedless" posting above me was using 25V+25V, is that twice the maximum voltage specified? Is that why he fried four transistors?
I've ordered everything except for the transformer because it's so confusing and there's so many different kinds, they also have different Ampere output.
Everything in this article tells me I should select the R-Core type Products - Custom Magnetics, Inc.
I'm happy to get an R-Core 200W 24+24V from here if it doesn't make the transistors hot like hell so I need a cooling fan?
Does the PCB or the instructions tell you the DC voltage required to power the amplifier?
If the suggestion is that +-22Vdc is about right, then you need a 0-18, 0-18Vac dual secondary transformer.
If your level of understanding of these topics is as low as you are getting confused with transformer ratings then I suggest you ask advice BEFORE you connect things up.
I also suggest you build and USE a Mains Bulb Tester to stop you blowing up projects because you have wired them up incorrectly.
I realised I have an amplifier on the way with a 200W 23V output transformer.
I think I'll just take the transformer out of that one and use it for this project.
The Antek transformers Transformers - AnTek Products Corp... do look very nice and at least one user here has confirmed he using a 400VA 18V flawlessly.
I think I'll try the 500VA 20V from them later AN-5220 - 500VA 20V Transformer - AnTek Products Corp
The price is very good, the shipping is a little high but perfectly fine for a 5 KILO transformer.
He said the 400VA is "a little warm" earlier in this thread, so I assume 500VA will be fine, and 20V is also fine since the PCB says up to +-25V.
He said the 400VA is "a little warm" earlier in this thread, so I assume 500VA will be fine, and 20V is also fine since the PCB says up to +-25V.[/QUOTE]
I'm not quite sure why anyone would want to use 500VA on this circuit.
120W would probably suffice, 160W about ideal and 200W overkill.
Output voltage 18-0-18 if rudimentary smoothing PSU or 22-0-22 if you intend to use regulated PSU.
Any suggestion what cases/enclosures from the Siliconray site would be recommended for this amp?
1. With a simple Cap PSU and fused output?
or
2. With a regulated PSU and speaker output protection?
Assuming toroidal transformer of say 200VA
Any suggestions?
So silicon ray has not responded to the guy blowing the bd139
Has anyone confirmed this board is working? Silicon ray, can you please respond it's been a couple builders blowing their bd 139 as soon as they hook it up. So how can they adjust the VRs with this happening.
who use 500VA? Maybe he was building a 8 way speaker...
Output voltage 18-0-18 if rudimentary smoothing PSU or 22-0-22 if you intend to use regulated PSU.[/QUOTE]
Hi
Im kind of sad to post this.
My amps are now working perfect.
I chose to replace EVERY transistor! Didn't trust them (see att.).What a bore!
The pic. is one of the delivered "MJ15003",in undressed condition.
(No porn!,more like opening a poor grave)
Heres a link you should see to compare the "innerguts"
Counterfeit Transistors
Jan
Jane?
