Rockford fosgate Punch 200S missing parts help !
I see more damage than just the missing components. Check out the mosfets on the power supply, the traces are damaged. It may still be repairable but will be a little more time consuming. Good luck with it.
yes but those of psu are 50N06 and gate resistors 47ohm everything else is cover, found the missing drivers are MPSA56 and MPSA06 but still don't know where place it, and eq pot value =(
This is a 150s but it should be very SIMILAR.
