GB Thread for Salas SSLV1.1 BiB shunt reg
Hmm ... let me try and take a stab at this.
There are 6 places where you can put in a LED in the board, all depending on your intended application. The 1-2 red LED recommendation is just for the voltage reference section. You can place up to 4 LEDs for the current setting section.
That is really nice news! Just a short question, Salas BIB guide recommends 1-2 red led(s). Your kit consists 6. Does it mean, that better to use more red leds? Thanks
According to BIB guide, 3-4 green leds go into the current adjustment section, and 4 green leds are included in the minikit as well. Red one goes to the Vref section.
Sorry about that, I should have checked the mini kit content before replying before. >_<
Anyway, if there are multiple LEDs per color included in the kit, they would most likely be there for matching purposes.
Please see this link for an explanation for the matching of the LEDs.
http://www.diyaudio.com/forums/analog-line-level/171715-salas-hotrodded-blue-dcb1-build-4.html#post2271531
It's from the DCB thread, but I think the concept is similar since it's still for a Salas designed shunt regulator.
In this case, your one supply for V+ may not need to match another V- side.
So it's more for more specific voltage setting. In this case the 4 LEDs spots with green LEDs will draw somewhat more current then the red ones.
The original proto's or first runs had 3 leds for current set.
shlomom
burningGecko
cucuclock
frankwilker
615498
coolzero
ohnsciolino - not valid user
taniknight
brathering
diy_calderon
mrsavage
Dane
BigE
dq10
azouts
ppap64
johnsciolino
danielkol
auxie22
exurbia
brathering
1dino
boston
markmorganadams
walter burkhard
Fabian85
jj506
Djinn
sbiswas1
Joonas
delecoy
Spriggs
jpautomatic
danielutzu
Integra
hearNew
chat72
heybobo
variometer
Ranchu32
Vega65
fff0
kimon
freeman
Malvin
carlsor
mikvous
rtd
cwtim01
edlinssen-notvaliduser
manaolo2001
Ralf Peter
Greg Stewart
yup
number 9
dubai2000
2wice
Haposai
volapuck
David A.M.
Here is my current unpaid list for all Salas Group Buys
It is quite long. Some of you I have sent Invoices for, others I have not heard from.
The last day to pay up is this coming Sunday 2/16/2014.
If you are no longer interested in the Group Buy, please remove your name from the spreadsheet if you can.
Otherwise please ask for a invoice via Private message, and include an email address for me to send it to. Thanks!!
