HI everyone. I found a couple of transformers from a Technics SU-V8. The amplifier was rated 150W x2 continuosly, and marked for 1KW of power consumption. Can enyone tell me more abuot that transformers? I found that they have multivoltage coils for the primary and mai output of 45+45 VAC, but i don't have idea about the power that i can have from.
Thanks in advance to everyone and apopogize for my english.
Using the information provided here, you should be able to find out:
http://www.diyaudio.com/forums/power-supplies/240849-how-know-transformer-power-rating.html
http://www.diyaudio.com/forums/powe...ansformer-ratings-cross-sectional-area-2.html
http://www.diyaudio.com/forums/power-supplies/156030-trafo-unknown-power-rating.html
In the case of a multiwinding transformer, you can use this method:
http://www.diyaudio.com/forums/powe...r-each-winding-multi-winding-transformer.html
Hi! and thanks! I can't measure the core because it's incapsulated. I found this: "National SLT5P195 117x98x80 mm 2 X 45 + 3,5 volt 3250 gram". I was looking for datasheets from Technics by replacement code, but i think it don't provide them.
hiHI everyone. I found a couple of transformers from a Technics SU-V8. The amplifier was rated 150W x2 continuosly, and marked for 1KW of power consumption. Can enyone tell me more abuot that transformers? I found that they have multivoltage coils for the primary and mai output of 45+45 VAC, but i don't have idea about the power that i can have from.
im in need of a technics SU V8 power supply thats 220-240VAC rated. would you be in a position to sell one perhaps?
regards
nigel, nigel@neble.net
