Hi
As the title says im Looking for 100-200va 2x65v toroidal Transformer?
Anyone know a store that sells these? i cant find it. It is so expensive getting one custom made.
Jørgen Solvik
Jørgen Solvik
I assume the Avel Lindberg Y23 series is familiar to you?
250 watt size is around $50-$60 each here (US) and you can get one at a lower voltage and add a few turns. I seem to remember it is about 3 turns per volt
Have you considered looking for TWO 33-0-33 200va transformers and using each one for one half of the supply. If you need advice on how to use two transformers in this way, please PM me and I will help.
Airlink do a 60-0 60 at 225VA. How important is the extra 5?, adding a few turns is possible.
Airlink
part is CM0225260
alan
The 5v aint that important as im gonna use it with a regulated psu from holton/aussie amps, to power my input driver stage.
Thanks for the tip 😀 Airlink has everything i need 😀
