Guys, why in the world do some companies use two tweeters in their design, such as this: Everest Audio - Focus-Audio-Master-3
What's the sonic advantage? As far as I can tell all this is going to do is cause cancelations and peaks in the response and ruin imaging. Anyone have a clue?
maybe it 'cures' or 'destroys' the fixed narrow listening window related to MTM designs
and it could give increased power handling, with less distortion
series connecting might have other advantages
They do it for the sake of SPL. Dynaudio does the same in
some of their products with special XO's.
Neat looking Audio Master 3 and nice pricing policy.
Altough not clear to me per pair or piece.
2200 € worth drivers, Etons and SS. Let's say a total of
4000€/pair for everything in DIY version with painting
done by a pro.
done by a pro.
It would seem to me that the window would become even narrower with this design.
if it does, there may be none at all 😛
The only excuse is SPL and possibly the extra sensitivity.
Generally though its poor option that causes more
problems than it fixes and smacks of lazy design
and focussing on visuals, not form versus function.
rgds, sreten.
rgds, sreten.
Yes I was thinking along Sreten's lines, more about making it different (for marketing) than making it better IMO. Just reading the blurb tells you a lot about the target market 😉
Tony.
Tony.
Generally one to avoid I would suggest as the distance between them is almost certainly bound to cause interference/cancellation effects, check the centres compared to the half wavelengths?
It can work in sound reinforcement where if they are angled and the tweeters have narrow dispersion (bullets?) the worst interference effects can be ameliorated. You also see this of course in line arrays with several tweeters in vertical array providing wide horizontal and controlled vertical dispersion. But even these have interference anomalies in the vertical plane...
I have also been puzzled by this. I noticed that those speakers that have two tweeters (and/or two midranges) sound very incohesive. Probably due to an increase of lobing.
In the CBT design however, several tweeters works great. Here with 72 dome tweeters.
It is my impression that the people at which these speakers are aimed keep their ears in their cheque books.
I'll be charitable and say that perhaps the designers are aiming for more diffuse treble, by introducing a certain amount of lobing.
Actually, if you do it right, two midranges can reduce lobing. Two tweeters, not so much.
The Keele multiple tweeter arrays can sound wonderful.
What's weird is that this makes the top model of some speaker brands sound all together worse then the next speaker on the ladder. That's the case with these two from Adam Audio IMO. Beta is a better speaker despite of a much lower price tag.
Alpha Mk2 - Description | ADAM Audio GmbH
Beta Mk2 - Description | ADAM Audio GmbH
maybe
but were we talking about a cheap speaker, it would be much easier to relate to 'this two tweeter issue'
that is my guess too, yes
apart from all 'known issues', I wonder if two tweeters would be possible to cross lower than one ?
maybe someone will try it one day, just out of curiosity
but I suppose all this have already been measured ?
until then, I guess we can only go on speculating about it
Three tweeters here, good listening report SoundStage! Hi-Fi | SoundStageHiFi.com | Aurelia XO Cerica Loudspeakers and here 6moons audio reviews: Aurelia Cerica
Aurelia Cerica Cerica | Aurelia
I think it would be ideal to lowpass lowest and highest tweeter around 4kHz... xo to woofers is 1500Hz
That's an interesting speaker.
Only bigger and heavier tweeter could be crossed lower
but not without drawbacks. This would not be significant
achievement IMO. We already have all what it takes to
get excellent sonics, altough some of DIYers would call
it rubish anyway. Nothing new under the sun 😉
Only bigger and heavier tweeter could be crossed lower ...
hmm ... I did not mean significantly lower
but when it comes to choice of xo point and filter order, it is well known that SPL matters too, so ... 😉
get excellent sonics ...
who are We ?
- Why 2 tweeters?
