Red Pilot (240)
I have several Pilots but I have no experience with using LEDs for bias. I've been meaning to give them a try sometime.
How good is the balance in that somewhat funky driver stage?
Pilot amps are highly praised for their sound. The 232 is widely considered one of the best PP 6BQ5 amps around. The Pilot integrateds such as the 240, 245, and 246, are built around the same basic 232 design. I've always found it odd, however, that paraphase inverters (as used in those designs) are generally frowned upon from a technical perspective. Same holds true for the Magnavox console amps, which have a loyal (some would say rabid) following.
My understanding of design and technical detail is, admittedly sorely lacking. And I've heard all the arguments against the paraphase - "not elegant", "not balanced", etc.
I like what I hear with these designs, though. =8^)
. . . Charlie
I also have a Pilot receiver pulled out of the recycling bin in our town.
The 240 was given to me by the father of friend but it wouldn't make any noise whatsoever. (Slowly brought it up using a variac.) When I did power it up I discovered problems with the filter caps and some of the resistors were charred and way out of compliance.
5 of the Telux LEDs, should get the bias to the right level, but I'll bench test it first and relate the results.
The Magnavox circuit uses different coupling caps to the output tubes. Does that signify it is the regular or non floating paraphase? Is the Pilot actually a floating paraphase?
In the Mag there are different coupling caps for the straight and the inverting out, and, as in the Pilot, there are also different cathode resistors. This is a regular basic paraphase, not the floating/see-saw. If you simulate the circuit on spice, and observe the low frecuency behaviour , you'll know why the different caps
