Selection an amplifier Pass in class "A"
Hello,
I would like to ask you for advice to select the appropriate amplifier Pass for listening classical music. Now I have Electrocompaniet ECI 2, which is very good.
I'm thinking about amplifiers from Pass Labs Aleph 5, Aleph 3 ...
I listen to mostly classical orchestral music from LPs (large orchestras, symphonies, concerts, ...).
Speakers I have 2.5 band with 65 liter bass reflex, made according the project to Zaph|Audio - ZRT - Revelator Tower. Sensitivity have approx. 90 db impedance is 4 ohms (may also fall slightly below 4 ohms).
I have upgraded turntable Lenco L75 + arm Jelco SA-750D + Shelter 90X cartridge.
Which amplifier will be right for me, Aleph 5, Aleph 3, or which else? Where can I find the most complete project for its construction?
Thank you for your opinions. Milan
Your amplifier is 2 ohm capable (2x150W and 2x90W 4 ohms)
and you would need a massive proper class A amplifier to get
anywhere near its capabilities. As it is it matches pretty well.
Its clearly not Class A beyond a certain point, but that is no
bad thing, its better than just clipping due to low output.
All proper class A designs basically usually can only manage
about half the power into 4 ohms than they can into 8 ohms,
unless specifically built for 4 ohms, and for 4 ohms they
should be designed for maximum output into 3R*.
Also note a higher than normal amplifier output impedance
in this case won't interact much with the broad very flat
impedance of the ZRT2.5, but will interact with bass tuning.
rgds, sreten.
* A compromise for class A, for Class aB you really should
build a 4 ohm amplifier to be able to handle 2R loads well.
I suspect the ECI 2 specs are into R, not nominal ohms.
ZM, don't you mean build them all, listen, decide? :clown:
ZRT 2.5 way doesn't look like it dips much below 4 ohms. I would consider an F-4 driven by a pumpkin or BA3 front end or an F5T with at least two pairs of output devices. An Aleph J with doubled up output devices should work as well.
Aleph J, F5Tv2 based on sound preferences. Or BA-3/Pumpie +F4, can't comment here.
I've tried the Aleph 4 and the F5, the Aleph has a far more subtle sound which to me is more pleasing to the ear. However, the Aleph 4 is a far more challenging build. The Aleph 4 is a monster at 100W Class A, it needs huge heatsinks and a huge PSU. ISTR it dumps about 400W of heat into the heatsinks.
PKI, thank you for the recommendation, but Aleph 5 has 26 db gain and Aleph 60 only 20 db and it's of little for use passive preamp.
Aleph 60 has better sound quality than Aleph 5 (for listening to classical music) and what is the main difference between them ?
