Anyone here with an Hifonics Colossus XX ?
My amp has blown and i need the codes from the drivers in second pic' cause mine are erased.Please help!
On the right side of the driver board, the one at the top is an LM211. You will find pins 1 and 4 directly connected.
The one below it is likely a TL072 but could possibly be a TL071. If pin8 is directly connected to pin 8 of the LM211, it's a TL072. If pin 7 is directly connected to pin 8 of the LM211, it's a TL071.
As a preventative option you might consider replacing those PS caps while you are in there. I replaced them with Panasonics ECO-S2AP332DA through Avnet Express. Jus a few bucks each. Mine had a similar driver transistor problem.
I didn't understood corectly and thats why i've asked you to show me on the pic'. It would help a lot,please.
I don't know how I could be more clear. Precisely what is it that you don't understand about what I wrote. The answer is NOT definitive. You have to check the pins to confirm.
Print out the text and bring it to him.
If he's doing repair work and doesn't use the internet, he's making his life MUCH more difficult. Without the internet, he can't even look up datasheets.
