I can get some birch ply locally but unfortunately it only comes in a maximum thickness of 8mm:
Plywood products ? Aircraft plywood ? Birch Aircraft GL3
They also call it "aircraft ply", thus will likely be charging an arm and a leg for it.
Are there any similar ply alternatives? This is the range I can choose from:
Plywood suppliers ? huge range of plywood products, MDF & wood panels
And a recommendation of thickness would be great. Thanks
I've been pondering this a little more. perhaps I can go for a constrained damping layered cabinet design.
maybe 8mm ply + 8mm particle board joined with green glue?
Or 8+4mm ply with heavy rubber sheets for a harbeth style enclosure?
Their "Marine plywood" looks like an excellent candidate to me:
Plywood products ? Marine plywood ? Decorative Cedar Marine ...
Marco
Great. Do you think 15mm would be sufficient, along with the heavy rubber damping on the side panels? Enclosure will be quiet small, about 11 litres.
Yeah, 15mm should be plenty for 11 L enclosures.
Marco
frangus,
bruynzeel in sydney or plyco in melbourne sells euro WISA birch its the best ply available in OZ 🙂
cheers
henry
cheers
henry
I'd go with mahogany:
Wood Densities
Density on its own is unimportant. If 2 materials are the same stiffness (some other properties play a role too), then the less dense (ie lightest) will usually have the advantage.
dave
Marine grade is definitely better then birch plywood. Dont know what is better then marine grade though.
I suggest you also readup on the approach taken by the "Harbeth" speaker guys - a little different to the usual ideas about building 'good acoustical controlled' cabinets.
Yeah I've read that. Thin cabinets, heavy damping, pushing the resonance lower. There was a thread on here once that discussed in a lot of detail, but I can't find it now...
If in doubt, brace the hell out of it (providing you don't want 1/4 wave style action) and it tends to offset the difference quite well.
Don't know about across the pond but if I couldn't find this local I'd go here.
This is a multi layer B-BB grade, not marine grade, which would be very expensive.
e.g. Single Piece of Baltic Birch Plywood, 18mm - 3/4" x 24" x 30" - Amazon.com
That second site on your OP looked liked they had a lot of products, maybe send them a email.
Thickness? 18mm-3/4" is very common.
There's some discussion of the issues involved here:
http://www.diyaudio.com/forums/multi-way/245965-how-much-cabinet-sound.html
How crazy are you planning to go with this project? Are we talking all out, no holds barred or rather a nice economy build?
Not very exciting but you can go MDF with epoxy coating and that'll take you quite far. Personally I'd like to go Birch-ply in my next build but you sort of start out with your goals and limits and then take it from there.
Its a 2 way monitor with Scanspeak 15W/8530 and probably Morel tweeter. I think plywood will be less labour intensive than MDF since I can finish it with a light stain rather than veneering or painting. It looks very nice too imo.
So what is it about Baltic Birch ply that makes it so popular? Is it the stiffness, density, flexibility...?
I'd try this stuff:
Plywood products ? Appearance grade structural ? BB Hoop plywood
Pine is very soft though..?
- Birch Ply alternative for enclosure?
