reduce noisy of amp
I have made a STK4192II audio amp and a LM1036N preamp.
So when I connect this with my speakers it get little bit of noisy, When I reduce volume from preamp that noise also get reduce, but when I listen to the music that noise also comes.
So what kind of thing should I do for remove this noise. for make sound clear?
Sounds like your preamp is noisy then. Noise takes many forms, and it comnes from many sources. You need to know what kind oif noise you have begore we know what to do about it. Is it hiss or hum or crackling or just what?
It is a hiss noise
The data sheet for the 1036 claims 80dB sn relative to 0.3 Volt which to me is a bit noisy but livable. However, your power amp gain is 101 which seems WAY too high which would aggravate your problem. You might try reducing the 56K resistors in the power amp feedback down to 15k which will push the gain and noise floor down about 12dB. If you have sufficient volume control range you can leave it there.
For LM1036N preamp I've used 100k volume controls.
I checked disconnecting preamp but noise still same.
But I didn't check with battery powered one, I'll check it.
Also I will post my project photos later, certainly.
The range of the volume control isn't the value of the pot 47K or 100K. My suggestion is to reduce the gain of the power amps by 12 dB. If the gain of the power amp is too low you'll have to turn up the volume control higher which might be a problem. Reducing the power amp gain will reduce its' noise independent of the preamp.
