Have to refresh page to post - error msg.
Getting the following error message, IF I have not been active for a while, even if I do a simple reload (not a reload + shift) and have tried to post:
Your submission could not be processed because you have logged in since the previous page was loaded.
Please push the back button and reload the previous window.
I have to go back and do a shift + reload. then it works.
Do I have a cookie problem??
How to correct it?
_-_-
PS. this has been going on for a while now, and did not happen except rarely in times past. It loses the post by going back, which is no fun.
I have several tabs open simultaneously, afaik I am logged in all the time... sometimes I leave the window open with all the tabs for hours or overnight, then I get this, even IF I do a refresh. IF I do a shift+refresh it is usually ok. Mostly this is annoying and wasteful of effort and time...
no moderators around, I guess...
Hi bear, we're here 😀
What you describe and are experiencing hasn't cropped up as a general problem.
Best advice I can offer would be to clear all browser history and temp internet files and run a general disk clean as well. That seems to resolve most issues that folk experience. Most seem to use a variety of browsers too, so make sure the cleanup covers all of them.
Once logged in I find I can open open as many tabs as needed and each automatically has me correctly logged in, and I can do the same with more than one PC at the same time.
