Hi there
i stumbled upon a german seller (that's where i got my Fostex FE206En from) which sells a correction network for rising response and for linearising of the speaker impedance
now i ask you fellow fostex users and others... is it worth it ?
Korrekturnetzwerk Fostex FE 206 En 1 Paar | eBay
I don't know if it's the same thing.You can make your own much cheaper mh-audio.nl - Home
The components values in the picture don't "add up"...
Unless you know the real circuit that OP is asking?! Is it the same layout? And what about the different values for caps and different number of components in a first count. If you know what the circuit/components are used please share with us. They say something about a publication that was on, whatever that means.
Korrekturnetzwerk zur Linearisierung des ansteigenden Frequenzgangs bei diesem Breitbandlautsprecher
Gefertigt mit hochwertigen Bauteilen von der Firma MUNDORF.
Absenkung des Mittenbereiches nach persönlichem Hörgeschmack!
3 Widerstände steckbar zur Feinabstimmung im Lieferumfang.
Inkl. Impedanzlinearisierung für Röhrenverstärker!
Siehe hierzu auch unseren Testbericht "IKE" Fostex-Flachhorn (KLANG + TON 2/2010) !
It means check the rating of the review i guess. i googled for this release and didn't find anything useful unfortunately.
Also yes... the numbers don't add up from calculator to this thing
lol what a Price! For 100 Euro you can buy Mini DSP that can do everything!
Everything ? Really everything ? Can it levitate ?
how about a simple 10 band equalizer ???
I have never heard a graphic equalizer that I wanted to leave in circuit...
But you would leave a "thingy" in there???
I have one, very 'P.O.S.H.'I have never heard a graphic equalizer that I wanted to leave in circuit...
It's on the shady part of the shelfs now. It was used to make small bookshelfs look like big floorstandings with good results, but not deserving mention. The floorstandings took their position. The GE is more like (Tapco T-231) a Dual 31 Band EQ, balanced ready.
Passives rule, more when they are a mystery or secret.But you would leave a "thingy" in there???
- Full Range
- Baffle step correction thingie from ebay
