Valve Itch phono
Joined 2011
Double post:)
I have tons of stuff but I havent had a TT up in 15 years, neither the vinyls which for the most part I gave away to some gfs young punkbrother long time ago. Thats why Its a little uphill track for me but since there is so many nice new releases now I am truly tempted.
I dug up some Sony Pro players (TTS something 2250?) without chassies the other day. They've been mounted in a custom concrete table at Swedish Radio. I'm tempted to mount one or two of those.
Joined 2011
Those I think it was. TTS3000
Joined 2011
Ok. My friend and I had a late night discussion about mounting the TTS3000s in, whats it called, wall gypsum plates? Easy to cut and could be glued in layers with som asphalt or so. Then a wooden frame around. Motor separated from TT alu and mounted in the gypsum. U guys think the TTs are worth an experiment?
diyAudio Chief Moderator
Joined 2002
Joined 2011
I can not, an I will ever be able to dream up any more disorganised way of handling things then in Windows 8. anyway here is Enigma.
And the boat im working with, and some storage
