Double post
I have tons of stuff but I havent had a TT up in 15 years, neither the vinyls which for the most part I gave away to some gfs young punkbrother long time ago. Thats why Its a little uphill track for me but since there is so many nice new releases now I am truly tempted.
I dug up some Sony Pro players (TTS something 2250?) without chassies the other day. They've been mounted in a custom concrete table at Swedish Radio. I'm tempted to mount one or two of those.
Ok. My friend and I had a late night discussion about mounting the TTS3000s in, whats it called, wall gypsum plates? Easy to cut and could be glued in layers with som asphalt or so. Then a wooden frame around. Motor separated from TT alu and mounted in the gypsum. U guys think the TTs are worth an experiment?
Salas this ebay offer is OK for gain? 6N2P-EV 6N2P Vintage 70s MATCHED PAIR STRONG !!! TUBES ECC83 12AX7 | eBay
All tubes tested at :
Ua = 250V
Ug1 = -1.5V
Test results:
Ia1 Ia2 S1 S2
mA mA mA/V mA/V
2.3 2.3 2.1 2.1
2.3 2.3 2.1 2.1
Where 100% is: Ia=2.3mA / S=2.00mA/V
We test our tubes from this type on High-End Soviet Military Tube Tester: L3-3, as pictured below!
Ua = 250V
Ug1 = -1.5V
Test results:
Ia1 Ia2 S1 S2
mA mA mA/V mA/V
2.3 2.3 2.1 2.1
2.3 2.3 2.1 2.1
Why not?
http://www.lencoheaven.net/forum/index.php?topic=1115.60
Why not?
I was thinking something like that but maybe some inches wider and a 12 inch tonearm. The few experiments I have been participating says I like non springmounted TTs but firmly mounted in well damped chassies.
Honestly direct drive also but those has some old school servo controlled belt drives that is supposed to work pretty well.
It's the same seller I bought the other couple.
Good for cold war ICBM and Ekranoplan tubes matching spec even.
Well. One has to love that control panel Im renovating a volt/amp meter (watt), gonna give u some pic when I get home
I can not, an I will ever be able to dream up any more disorganised way of handling things then in Windows 8. anyway here is Enigma.
And the boat im working with, and some storage
- Analogue Source
- Valve Itch phono
