Valve Itch phono
diyAudio Chief Moderator
Joined 2002
This morning I powered the Itch but a big sound happened & red led from SSHV2 don't lit: tested the SSHV2 two DN2540 fried, one SK117GR fried, one KSA1381 fried & the three diodes fried. I only have one DN2540 as spare so I need to order more to test the Itch:)
Is that the Itch you had made a long ago and was playing OK or some new build attempt?
Joined 2002
P.S. That is all very weird. Not having a channel suddenly, seeing problems with 18-20K when Revoli had 3.3K for Dyna 10X4, seeing problems with diode trick when neskor could use leaky valves with that successfully, power on burn out on a long servicing build...voodoo stuff.
