Options for paper coaxial with soft dome tweeter?
speakers exist: Boenike Studio 12
AUDIOMANUFACTURE BOENICKE AUDIO Studio 12 STUDIO MONITOR
they question is who makes the drivers and who resells them.
http://www.tb-speaker.com/detail/1230_04/w5-1701s.htm
or..
http://www.tb-speaker.com/detail/1230_04/w6-1530s.htm
..looks more like the latter of the two.
Which is independently measured here:
http://www.hobbyhifiladen.de/Lautsprecherchassis/Tang-Band/Koaxial/Tang-Band-W6-1530::901.html
Plus, it seems it's the only place you can purchase it from.. For that kind of money go back to the CEntrance speakers..
If it uses a dome tweeter then you'd probably have to get one with a waveguide or where the cone acts as a waveguide since otherwise there probably wouldn't be a smooth transition in directivity.
Or you could buy a normal cone driver with phase plug and then just put a small cone tweeter in front of it and get this result =)
After filters the tweeter has a 12dB/oct acoustical roll-off @ 3 khz and the mid has a 6dB/oct @ 3 khz.
This is a dipole though so might not be as smooth with a monopole.
Looks like this is the only option: B&C 5FCX44 5" Professional Coaxial
B&C 5FCX44 5" Professional Coaxial Speaker 70° x 70° 8 Ohm 294-5760
or for the 6", FaitalPRO 6HX150
FaitalPRO 6HX150 6" Neodymium Coaxial Driver 8 Ohm 294-1192
thanks for all your input guys!
Actually when you move into pro units with concentric compression drivers you'll have more options, but they aren't soft domes.
http://profesional.beyma.com/ingles/xls.php?xls=06_COAXIAL DRIVERS
Home
Yes, the pro stuff. So I guess the non-metal (keytone, polyester, etc.) diaphram would be the closest thing to the soft dome tweeter.
So that leaves me with
Beyma 5CX200Fe -- looks easy enough to crossover
B&C 5FCX44 -- similar crossover idea as beyma
FaitalPro 6HX150
BMS frequency response looks like it's gonna need a notch filter for the coax woofer.
FaitalPro 6HX150
Even the poly diaphragms (and surrounds) don't sound like soft domes.
(..obviously in a general sense they sound alike, but the same is true for metal diaphragms as well.)
-and "metal" doesn't always sound like metal.
As far as being well engineered, the KEF replacement parts that ra7 mentioned are quite likely the very best available within certain excursion/power limitations (..ie. loudness limited). Scroll down and look at Zaph's measurement of the KEF Q100 results:
Zaph|Audio
Also see gornir's measurements of the KEF SP1632:
www.audioexcite.com KEF SP1632
Note that the midbass/midrange portion doesn't have the typical "ringing" (or high q "bell" resonance of most metal diaphragms).
..both are more of the midrange-up variety than midbass, but KEF has some midbass coaxials as well (that are a little larger).
You searched for kef | Speaker ExchangeSpeaker Exchange
