The Phonoclone and VSPS PCB Help Desk
My calculations:
Sumiko BluePoint EVOIII Specs:
Load Impedance 47k Ohms
Output Voltage/Channel 2.5mV
Calculating with Richards spread sheet makes:
See attached picture.
Am I doing this right?
OK, I just got my resistors for the above Phonoclone and have another question. For R1=135, should I undershoot with a resistor value of 121ohms or overshoot with 150ohms? Same thing for R2=540, under at 511ohms or over at 562ohms. Thanks in advance.
Dave
Here is my earlier conversation with Richard. I would order one set over and one set under as the exact values are hard to source.
One thing I did is to solder sockets 1-1571994-0 Product Details - TE live these into the resistor holes on the board. That way I could try different ones out or go back to stock vales if I wanted to try a LOMC cart. Just cut it apart into single sockets and solder them in. I'll see if I can find a picture of what I did to clarify.
Great minds think alike :) ... I use them too. Unfortunately they are rather small for more some of the more exotic resistors which has a thicker lead. Do you know if there's a version with bigger socket hole?
