105v trigger.
I also have solar cells, but at 12V instead of 110V. The black box at the wall is a switching regulator designed of my own.
it have 4x250watt.they were parallel until now and was producing 5kwh/day,almost all my house.but now i want to add two more because the winter is coming and the current would be huge so i changed to series connection.
p.s.i tried a 30v relay with 91v zener and it seems to work.i will do more testing tomorrow.
Won't the panel voltage rise once the load is disconnected, causing the relay to behave like a buzzer? Maybe it's better to just isolate the panels with a rectifier. You can spare a diode drop, and DC will be prone to arcing if you don't use the right kind of contactor or some kind of semiconductor switch.
