JC-80 eBay PCBs
Dirk,
are you deaf?
A source that has an output noise of 0.1mVac 20Hz to 20kHz is atrocious.
Apply that to a headphone or to a power amp or to any subsequent music replaying system and the signal to noise ratio is unacceptable.
You're assuming that all of the noise from the power supply comes out of the output from the amplifier and that is not the case as I tried to explain.
@dirkwright: I experience you as generally rude. The above is no different than what you did to me except you could not even find the information IN THIS THREAD. One or the other of us needs to stop posting here, Which shall it be?
Erno's shunts
. I use Erno's shunts, they are very good, but very expensive to build, many of the original semiconductors are discontinued (389/109, 313/2013), maybe there are substitutes you'll have to see.......
I found 313/2013 on ebay from Israel. I used them for my KSA 100 MKII. I hope they work. As for the 389/2013, I hoping to find subs 2SK170/2SJ74. If I do, if I understand this to be correct in some readings, that 389/109 are two in one jfets, so that I have to double the 2SK170/2SJ74s. Yes?
