Press-n-Peel Blue is expensive $2 per sheet
And Rs 70/- per dollar!
Roushon.
DEAR SIR
I WANT A ECONOMIC FINE PCB BOARD(COPPER CLAD) CUTTER AND 60 A AMPERE METER
I use acrylic cutter for this purpose. See the attached picture. Go to any hardware store and ask for `acrylic cutter', it costs around Rs 50/-, purchased long back, may be more now.
Such Ampere meter is available in big electrical goods shop.
Edit: You have to slide the cutter softly on both sides of the board and when it is weak enough, break it. It needs practice.
Edit: Or you can use plane saw blade used to cut iron rod etc.
Roushon
DEAR SIR
http://i42.tinypic.com/og9bw4.jpg
i am using this, order from ebay(was not available in local hardware store) around 2.28 USD, quality inst that good better to say poor , blade run-out after 3-4 cuts. look for same kind of thing.
Here is the details of the shop I mentioned before. Drill bits of all sizes, hot air guns (Rs 350/-), MX crimper (Rs 300/-) and all kinds of tools. (Crowded and tiny shop.) Drill bits Rs 5/- a pieces (0.8mm, 1m I purchased).
Roushon.
Hi Roushan,
yesterday visited this shop and i purchased 5 types of drill bits in qty of 10 at 5 rs each. i have not tested quality of drill bits but looks good, earlier i used to purchase from LR and item cost was 15-25 rs each. you saved my lot of money. now i have vial full of drill bits.
i also brought acrylic cutter only at 60 rs and 4 additional blade 10 rs each blade, quality good.
thanks to only you
Hi Roushan,
thanks to only you
You are most welcome! I am very happy that my effort is helping hobbyists.
Roushon.
where can I buy a Cheap laminator for PCB toner transfer
me too looking for Cheap Laminator
You were in Lohar chawal yesterday did you check for Lamination machine in Abdul Rehman Street. I believe that chromo paper + lamination machine + TRF should produce pcb with very fine track.
May I ask why do you require so many drill bits. Do you have a work shop.
i was not aware Lamination machin will available at Lohar Chawl, next time i will defiantly check at location suggested by you.
i live in Uran which almost two and half hours to Mumbai and my office hours dont allow me to spend time on other things . so usually i buy in quantities so it can run for 2-3 months easily .
There are a wide variety of Chroma/Video transistors with specs similar to the 2sc3503/2sa1381 pair. Alternatives include the Toshiba 2sc3423/2sa1360, and numerous Sanyo and NEC BJTs like 2sc3953, 2sc2688, etc. In most cases, the NPNs are very easy to find locally, since they were used in high-volume (obsolete) CRT TV appications, while the PNP complements may be unobtainium, but look around. Nothing beats the 2sc3953 on linearity for a high-voltage VAS transistor, but the PNP is unobtainium locally.
If you're not concerned with the low Cob and high Vceo specs of the chroma transistors, then there are higher-current driver transistor pairs that are readily available: 2sc2690a/2sa1220a, 2sd669/2sb649, 2sc4793/2sa1837, etc.
Does anyone know where we can get 2SC3503/2SA1381 .
I assume that Mumbai is the place for this. Any other places like Delhi / Bangalore ?
Mouser has it but shipping is a flat $40 and duty about 30% makes it not worth it .
Hi Ashok,
See if the following is of any help:
http://www.diycomponents.in/Category.xhtml?category=TRANSISTOR
I think you can also tell them your requirements which are not in their website.
Roushon
Thanks! Little bit of fun in the world of `conductor', `semi-conductor' and `non-conductor'...
Roushon
Hello,
Rakesh Sharma from Jodhpur, Rajasthan.
Want to know availability of TDA 7294 IC ?
It's not available in Jodhpur or Online.
Can you help me in purchasing these IC, i need 8 of them.
I want to put them inside this PC Case mod I have done.
http://www.techenclave.com/community...-1-amp.151052/
Hello,
Check the following (expensive) ebay option.
http://geb.ebay.in/g/ImportHubViewI...IFIER-IC-AUDIO-OUTPUT-IC-SHIP-FROM-CALIFORNIA
Roushon.
- Design & Build
- Parts
- Parts in Mumbai (India)
