Voltage in the base of Q104 (first BC337 on the positive ccs) is 16.6v and should be 22v
Voltage in the 10 ohm resistor is 14.8v and should be 19.4.
What is the output voltage if you disconnect the led-chain (just remove the adjustment resistor).?
After a nice Risotto,
Frans.
Frans.
Risotto ?
Frans, you @ the wrong side of the mediterranean
4 to get a proper Risotto. 😱
Maybe Paella or lookalikes....
Frans.
After removing R105 and so disconnecting the led chain I still have 12.9v at the output.
Finally nailed it 🙂
After some mind stretching I decided to replace the mosfet driver bjt with a stronger one (highe hfe) and now everything works normally.
Now is time to build the external riaa filter for both boards.
PS: Led testing with a 9v batt can be a total disaster.... I managed to burn some leds this way and replacing them proved very board damaging.... DO NOT ATEMPT THIS AT HOME.
What was the old hFE and the new hFE?.................. I decided to replace the mosfet driver bjt with a stronger one (highe hfe) and now everything works................
That is very strange.
20% more hFE does not seem like the change that cured the problem.
Look for something else.
I just got my Paradise up and running yesterday and am listening to it now - simply astonishing - the best phono stage I have ever heard - I can't praise it enough!
Good to hear/see.Have you and Si been able to do a comparison between power supplies?
No, not yet - but I have wired it up the same way he has so it will be easy to try.
The grip and dynamic is quite astonishing though.
many thanks
Fully deserving - remarkable in every way. Can I ask, how does the Paradise compare to other stages you have designed (like the modular)?
I think that depends on how you build it. The best version of the Paradise i heard had a tube power supply build by my Lithunian friend Andrejs. That sounded as good as it gets, particular tonal shadings and colors.
What i found is exceptional with the Paradise is bass. It is very dynamic, deep and tight.
It is also very low noise.
The boards where conventional stuffed as in the guide that Hesener made.
No exotic parts.
No exotic parts.
Hmm... Transistor stage but valve power supply - an exotic combination. I would agree that the bass is remarkable - not its only strength though 🙂.
Finally someone coming up with a prereg. 😀I just got my Paradise up and running yesterday and am listening to it now - simply astonishing - the best phono stage I have ever heard - I can't praise it enough!
Just to spoil J.G.s comment, he still had'nt the chance
to listen to the prereg until now.
We'll get that straight soon....
But,
YNWOAN,
why did you replace the foil C's with something else ?
Those you got with the Kit were chosen by some reason....
I had it working with a proto of the pre regulator.
Maybe the finished one is even better.
Anyway, that is the finest stage that our team can design for DIY.
I heard not one commercial stage that betters it in total.
It is semi affordable and making it any more complex would bring many in trouble.
There are many ways to tune it though. One is the Calvin buffer.
I plan a gathering where we can compare. The amount of people will be quite limited though.
Hopefully i'll be one of the chosen few....😉
One board finished with external riaa... powered it up and no problems.... input offset zero (loaded with a 47 ohm resistor)... output still wondering a bit.... will let it burn for a while 🙂
Second board powered... no voltage on negative side... search for shorts... remove smd caps, replace smd caps... now + - 18v steady.... input offset (loaded at 47 ohms) = 0
Output offset wandering a bit.... -12 + 34 mA.... so far so good.
Only one issue, this worked out board has some strange behavior at startup.... the 2 led string in the positive ccs glow hard red for half a second before they steady as normal green at power on..... maybe I need a softstart 🙂
- Analogue Source
- Paradise Builders
