Made a 2 speaker shoebox "boombox" want to amplify
I have no experience with wiring,speakers,onhms etc,..but know how to use a multimeter for certain automotive related repairs..
I decided to try and make a 2 speaker stereo, and fit them in my shoebox,..eventually got everything wired to a 3.5mm headphone jack to use with my phone..powered on and works,..but low volume for my taste
The way i wired the speakers was negative to negative from each speaker, with 2 wires from the headphone jack connected to those wires, and each positive of each speaker connected to 2 wires on the headphone jack,..so if i decide to cut off the jack ive got left(-)(+) right(-)(+) to solder onto an amplifier(Did i wire my speakers series parralel,?) (4 wires total on headphone jack)
My question is each speaker is 3 ohms 2 watts max,..what kind of amplifier can i make or buy that will work with these using a 9v/12v battery,..ive got a LM386 DIY , and PAM8403 3 watt dual channel bookmarked...i want to push 1 watt to each speaker and 2.5 ohms on each speaker(sound right?)
If someone could make a wire diagram of my setup with a added amplifier configuration,
im new to this stuff, and decided to start learning
Place a divider in the box to separate R from L.
Find a 5 ohm 5watt resistor and place in series with each of the + speaker leads and try a pair of LM386 amps.
Have fun learning.
Whats a divider?
heres my speaker setup in a circuit
Mount the resistor like this? and how would i wire both LM386's?
Theres no need for any freakin resistor!
The way Id wire this thing it would look like this:
print screen
Then wire it to ur 386, solder both signal wires together and you get mono signal.
2 gnds too..
If you want stereo... Then theres no need anyway. You need 2 speakers but they should be alot further away from eachother.
I see since i would wire them in series i equal the 6 ohms of the speakers and decrease watts needed, to get 6 ohms for both..then i can push 4+ watts without getting hot..., if i want stereo through the amp i would wire them in parallel which would defeat/burn the amp? so then i would wire each speaker into 1 lm386 each and tie both amps into 1 switch,1 potentialmeter?
