Try using the headphone jack for testing. Since they don't get used much, you might have plug into the jack severl times to get contact... Also does it have preamp outs? YOU need to jumper pre out to amp in....
Yes, correct. The RCA/phono connectors for preamp to amp in was labeled "Accessory". Thank you.
