Scott, the interesting thing is that the topology of the device you sketch here is identical to that of the Byebee. One wire in, one wire out.
So, at that level of abstraction there is no fundamental reason why a one wire in, one wire out device could not work, of course within certain parameters, and necessarily always accompanied by a degradation of the original signal.
However, intelligence and memory are required to add a fourth force to the RCL trinity , and I don't see a location for this in the Byebee. Or its proponents.
Don't forget you always have to have a second wire (return, 0V, GND, ground)😀
Who knows - maybe you are right regarding the Bybee´s 😀
I do not know if the Bybee´s should be called a quantum device or even if they work on a quantum level?
However using materials that are the least influenced by unwanted quantum effects, or using a "filter" that attenuates the unwanted quantum effects or actively controlling the quantum effects are very interesting as it is not only affecting audio performance.
simultaneously backing away from claims/insinuations you made that can be (or have been) argued, while furiously waving hands and making vague, yet strangely authoritative assertions, without actually saying anything of meaning.
I suppose its too much to ask you to name any of these so-called desirable quantum minimizations, or alluding to quantum methods, which might be enlisted to distinguish which are the wanted quantum effects and which are unwanted …
surely you must have some idea what they are, as you find it so very interesting? given these mysterious quantum thingos dont just impact on audio performance and all, but have such wide-ranging application to the universe in general, you must have thought about this a great deal?
I suppose you will say something like you arent going to take the time to educate the unenlightened with our closed minds, you have better things to do? or perhaps these discoveries are tied up in the many and varied patent applications for quantum doo-dads poised to make millions? if you told us, you would have to kill us?
utter gibberish 🙄
BTW: Brent Butterworth just posted in FB and elsewhere that loudspeaker cables really do make a measurable difference, anticipating an outcry of dissent. My comment was that it has NEVER been about them not making a difference --- but that when they do, the differences can be accounted for by standard electromagnetic theory. Or not. Even the proponents of bizarre physics should at least understand, and carefully account for, the basic EM. After that, as the preacher says to Sheriff Bart in Blazing Saddles, you're on your own.
Dick Greiner, oh, about 1979. Took Brent 35 years to catch up?
Phase Response Does Matter......
Even on my netbook micro sized speakers the differences between the two audio passages are easily audible.
What is the frequency vs delay response of typical systems...ditto higher end systems ?.
I have heard ferrite clip on filters causing a hardening/harshness in the subjective sound, I have also observed another particular clip on filter of same form factor to cause increase in peaks amplitudes....and subjective cleaning and detailing of sound.
Anybody here have the gear to (easily) measure the frequency vs delay relationship of a typical clip on ferrite filter placed around an audio interconnect cable ?.
Dan.
Allpass Filters - Blog - Universal AudioThe Bybee is called a noise filter. I gave my opinion that it treated complex waveforms differently than simple ones. Scott seems to think this violates the rules of the game. I don't think so.
As an example of a device that would treat the amplitude of simple waveforms differently than complex ones is an all pass filter. If you just swept it with sine waves and only looked at amplitude, if it were working correctly you would not see an amplitude change. If you tried a square wave due to the phase change on the harmonics the waveform would change and you would see a different maximum amplitude. (Of course the delivered power should not change.)
Now what is causing the results measured is certainly open to opinion. So when I post my results there will be enough information for those skilled in the art to duplicate my tests.
Dan.
If you're talking about in the audio band, yes, anyone with a sound card can do that. You'll find that there's close to zero effect.
Ferrites adding a little distortion is based on science. This is because unless the wires through them are truly coaxial* there will be some magnetic field coupled to the ferrite.
Magic boxes subtracting noise is based on fantasy.
* Coaxial is not quite the right word, I know. jn uses the proper term in his posts, but I can't be bothered to do a search.
Thanks In Advance...
So can you detail the effects at audio frequencies please.
Dan.
"Close to zero effect" is not zero effect.If you're talking about in the audio band, yes, anyone with a sound card can do that. You'll find that there's close to zero effect.
Dan.
"Close to zero" means waaaaay below any audible threshold- their effectiveness is at RF, not at audio. The specifics will vary from filter to filter. Nearly all of the clamp-on devices have cutoffs at 1MHz or (usually) higher and a low Q. What's the resulting phase shift at 20kHz from a second order filter at 1MHz with a Q of 0.4?
I love you folks. Although, as a disclaimer, it's very warm here and I just had some sauvignon blanc and pinot noir.
I hope you drank them separately . . . 😀
And tell us you dont put ice in your wine either!
I understand true coaxial, what does JN mean ?.
Dan.
I am not averse to using a ferrite here and there to stop i.a.o things emitter follower oscillation and RF ingress.
I'm a reasonably good listener and cannot hear any difference.
Use them with confidence if their effect only starts at a few MHz - after all the class D boys have no problems with them at 300 kHz, thats for sure.
Yes, in fact I cited Greiner in a reply to his FB post as recommending that amplifiers be close to loudspeakers if possible and line level signals be the sent over the distance if needed. But Brent's a little defensive as he's been catching a lot of flak lately, after endorsing some Bose noise-cancelling headphones, which brought Steve Guttenberg down on him. So it goes in the wacky world of audio reviewing.
In sequence for the most part. And I save the ice for the Romanee Conti of course.I hope you drank them separately . . . 😀
Actually the guy most responsible for my appreciation of wine was the late actor Lawrence Harvey. He used to drink a prodigious amount of white burgundy and had it imported by Vendome, and supposedly got the entire production of a small operation in France each year, hundreds of cases. I was too young to buy wine at that time, but occasionally he'd bestow a bottle on my father, on whom he relied for audio in his various homes. When I tasted the wine I realized that there was a substantial difference in quality compared to the plonk I was allowed small amounts of at the house, usually jug wine from Almaden.
I'm reminded of this because Harvey actually did drop an ice cube into his if it wasn't cold enough, according to my father. By the way, he died of liver disease.
What a passive quantum purifier do are simply to
If one declares his Hi-End gadget device is working at a quantum level, he can turn to wikipedia (like I did now) to bring out all sorts of quantum effects as a defence against “non measurable claims” .
Turing paradox, Quantum Zeno effect, wave function collapse, all can serve him as a demonstration (to the masses) that it is the attempted measurements that affect or alter the operation of the device. All these have catchy names too!
Stubborn observers (e.g. SY) will spell “Schrödinger equation” but hey, this is all about a mere audio gadget.
Is there anyone from the people who have a grasp on these physics, ever go into applying such rigorous analysis to prove (to the masses) that the gadget is not an elephant?
Besides, can we prove a negative?
Hence:
Beam me up Scotty.
George
PS Pop corn, peanuts and beverage consumption seems to increase every time a product with a “quantum” tag shows here and this is a macroscopic domain effect worth measuring (for the masses)
I know it's esoteric but decreasing the entropy of information is covered by the second law, it must use energy and have a net increase of entropy to the universe. Transmission of informatin in a lossy medium has an increase of entropy going backwards must have a penalty.
Yes, quite, there even was a Professor at Delft Technical University who postulated that the evolution of intelligent life necessarily followed from the second law, since that would be the quickest route for the universe to achieve maximum entropy.
I don't think that's it. Clearly, being a quantum device, it behaves much like
the delayed choice two slit experiment - You the observer make the decision
about what constitutes noise and the Bybee merely acts in anticipation of
your decision.
LOL.
Yes, but that return is outside the Bybee so it is a two wire device.
Oh, don't be such a W.I.M.P..😉Did you know ---- ?
it was thought that the speed of the expanding universe at the edge was slowing down. Wrong!
Now they cant understand why it is doing just the opposite.
A confusion of perspective, perhaps?
-RNM
Weakly interacting massive particles - Wikipedia, the free encyclopedia
Currently working on a liquid argon time projection chamber. I never knew that liquid argon could support 2 megavolts per cm. whoa.
Dan.
Bingo. Common centroids.Dan, AFAIK current centroid.
jn
Quantum Schmantum
Thank you for that George! Well said. Besides, before discussing any potential cause of a measureable "noise" reduction, hadn't we deal with the main issue here:
AFAIK Ed merely said there was a difference between a resistor and the device. He had not yet quantified WHAT the difference was in terms of reducing unwanted noise as opposed to identical noise which is part of the program material.
Until this issue is resolved any discussion regarding quantum anything as applies to the device is spurious and amounts to little more than regurgitation.
I have to admit to quite a bit of skepticism, without dealing with any quantum effects in conventional electronics we are now receiving signals from Voyager 1's 18w transmitter. It is now out of our solar system, with received signal strength less than -229dBm! OK, so the 70M receive antennas have upwards of 60dB gain at 8GHz, but I'm straying from my point. To construct a communications system with far more path loss than a 1M piece of wire (315dB more, for example) does not require taking into account quantum effects in that path. Well, now that I think of it, as in this forum maybe there is a bit of Dopeler shift (sp intentional) now and then.
I am encouraged by the focus on trying to measure things people claim to hear. Thanks, Ed!
Just my 0.02 quanta.
Howie
Howard Hoyt
CE - WXYC-FM 89.3
UNC Chapel Hill, NC
www.wxyc.org
Hence:
George
PS Pop corn, peanuts and beverage consumption seems to increase every time a product with a “quantum” tag shows here and this is a macroscopic domain effect worth measuring (for the masses)![]()
Howie
Howard Hoyt
CE - WXYC-FM 89.3
UNC Chapel Hill, NC
www.wxyc.org
- Member Areas
- The Lounge
