hello ,
Here is my ampli has 2 audio ways with 2 ECL 805, the plan of the assembly , l together made with elements of recoveries(recyclings), only, the transfomateur torique is new.
J have to copy on l ampli ECL 82 and ECL 86 for etre the best adapted, l ampli go out 5 W under 1000 hertzes is 8 ohms, he works well between 300 and 18 000 hertzes, down transformers are not well of has their conceptions
The tube at the center is a rectifier? Cathode at top? It´s like a EY8x... or not?
hello ,
yes , it is the " EY 88 " , use to 235 V= and 100 mA for 2 ECL 805 😉
the link to video
Ampli Stéréo ECL 805 - 5W sous 8 Ohms - Vidéo Dailymotion
hello ALL 😉
me up me build 2 ways ECL 805 for possible news build ...
very good sound for little power , approximatly 4 W 🙄
bye , good day and good happy christmas
oups , error in shematic !!!!
i me stupid ...🙁
Hi !
Nice one. You helped me very much, I could not find the schematic of PCL85 single ended in well performance. like your one.
I guess it sounds much better in "full-triode" than in pentode mode without any kind of negative feedback.
Enjoy!
Martin
PS: Have you tried to include the OT secondary in the cathode circuit for local feedback? It might help your frequency response a little.
Enjoy!
Martin
hello Martin ,
Rather long has to adjust, i have to check(control) effect on G1 of the penthode, has every modification l is good but we can again improve this assembly , i joins curves with 1.5 V in G1 and 2 V in G1 on the triode meadow ampli
Some food for thought
6F5P SET Amplifier
SPICE Design of 6F5P SET Amplifier
Spectrum Data for the 6F5P SET Amplifier
John
6F5P SET Amplifier
John
- Tubes / Valves
- 2 ECL 805 SE
