anyone knows if these amps are triode or ultralinear connected ?
http://www.ebay.com/itm/261255093156?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
he claims triode but i read on the web that this are ultralinear so i dont know if i can trust him
HARTUNG-SE-2x3, Hi Fi- Vacuum Tube Triode connected Amplifier
At the very low power rating of the amps,they are no doubt triode connected but here is another thing.Since they are OTL,there is no way you can connect them in Ultra linear.
OTL tube amplifier with one output pentode but capable to feed 3 W to 4 ohms loudspeaker. Interesting, but hardly true.
I suppose that it is an ordinary SE amplifier. There is clearly a transformer box at the rear part of the chassis.
I call it misleading. The website is also quite vague. There's a picture of the amp in question, but no mention that it's OTL.
jeff
Looks like OTL, from the manufacturer's website. It makes the following bold claim.
Hard to tell what is in the box behind the tubes but judging by the size of the output posts in the picture it is not very big, Unlikely that there could be two output transformers and a power transformer in there but who knows? Also there are no taps for 4, 8, 16 ohms like OPTs usually have. The speaker outputs are rated for 4 ohm, as stated on the website.
Only four tubes for a stereo amp? The outputs are 6P1P-EV Russian military(!) tubes. The driver/splitter tubes are 6S4P-EV military tubes (in pure single triode, whatever that implies).After many years of repeated tests and improvements our OTL technology gives a true sound and is among the finest available on the market today. After many years of repeated tests and improvements our OTL technology gives a true sound and is among the finest available on the market today.
Hartung OTL
ebay link not OTL
Ebay link shows SE amp with 6P1P-EV tubes and those can't make 3W in triode connection (if EL84 makes some 1.5W in triode these can only be less) so it's either UL or plain pentode (perhaps with Shade feedback)
OTL link on vendor's own site shows rather beefy 4x6c33c monoblocks and those do make sense but have nothing to do with the amp OP inquired about
Looks to me like two transformers in the cage to the left and right.
a single 6P1P-EV is not going to drive a 4R speaker without a transformer. They will make 3W in UL mode if you push them, but not in triode mode.
http://www.diyaudio.com/forums/tubes-valves/165494-firefly-single-ended-tetrode.html
The web site does show OTL amplifiers, but they run a quad of 6S33S tubes.
This is his ad so that is what I was going by.
Item specifics
Condition:
New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is ... Read moreabout the condition
Type: Power Amplifier
RMS Power: 2x3 W Number of Channels: 2
Channels: 2 x 1 Channel Brand: Hartung
Speaker Outputs: 2 Model: Output Transformerless
RMS Wattage: 3 Watt /4 Ohm/ each Audio Inputs: Stereo L/R RCA
Hartung classic tube amplifier: SE Number of L/R RCA Inputs: 2
Hartung: CD or Mp3 stereo all purpose amp Audio Outputs: Banana Speaker Jacks
I´ll skip this one 🙂
Build your own. TheGimp's Firefly looks like a neat little amp.
jeff
jeff
TheGimp's Firefly ? dont know that amp.
I believe the author posted a link, but it seems to be broken, so here it is again:
FireFly Single Ended Tetrode - diyAudio
jeff
jeff
See if this link works better. For some reason, links derived from searches seem to break.
http://www.diyaudio.com/forums/tubes-valves/165494-firefly-single-ended-tetrode-1.html
I would use the Edcor GXSE GXSE10-8-5K or possibly the GXSE15-8-5K transformers if I were to build another.
The two amps are still in service and used almost daily.
- Tubes / Valves
- Triode or ultraliner connected ?
