i have an Audio Source 16bit 12S 48 khz and want convert this to 44.1 khz. I know i must use an SRC like the 4192 from TI.
On the Datasheet i cant find any settings for an 16 Bit I2S source.
Works 24bit i2S?
Any Idea how to do this? Thanks...
Works 24bit i2S?
You could stuff zeros for the 8 least significant bits, to make the 16 bits look like a 24 bit signal. Assuming the data rate conversion uses a "poly phase filter", most if not all of the new samples will be 24 bits, the 8 LSBs not all zeros.
Hi from a fellow ham
Off topic... Hello from AB0N 😉You could stuff zeros for the 8 least significant bits, to make the 16 bits look like a 24 bit signal. Assuming the data rate conversion uses a "poly phase filter", most if not all of the new samples will be 24 bits, the 8 LSBs not all zeros.
