Funniest snake oil theories
jan -
Much obliged as I believe the Stradivarius wood is from the South and should be much warmer in tone, no?
I admit that I was a bit worried as Baltic birch gives a cool sound, given its growth in more northern climates.
I am quite firm in my opinion based on my listening tests, but I am wondering what wood grows in central Europe because I think it may give a more balanced sound. My search continues.....
Look up which year the Stadivarius vilolins were build...
I very much enjoyed the news story that came out a couple of years back, that in a DBT, violin players were unable to tell which violin was a 'Strad' and which was modern. The fact it was players and not just listeners was important, as a player who knows they're holding a 'Strad' will automatically play it 'better' than he would a bog standard Yamaha or whatever, further perpetuating the myth.
Double-Blind Violin Test: Can You Pick The Strad? : Deceptive Cadence : NPR
BTW, the EMI filters you posted are 100% completely and perfectly ineffective against the spectrum linked by Mr Push Pull, measurements which correlate spot-on with many I made elsewhere. That should be instinctively obvious just from picking one up and examining the component size, and easily confirmed with a spec sheet.
You've skipped half the picture. More than half, really, you skipped the important part. What does the DC coming out of the power supply look like and what does the output of the box of gain look like? If I have, for example, 10% third or fifth harmonic on the power line, the DC might even look better than from a pure 60Hz sine wave.
Why some people act incredulously. Response to push/pull
I have a partial solution and a partial answer to the topic in question.
1. With interconnects, use balanced cables. Then it can be connected only one way.
2. The partial answer to the bigger question as to why some people think the way that they do with no logic or reason? The answer is simple. Some people are just CRAAZZYY. There is just various degrees of craziness. There are the functioning crazy at one end, then there are the ones that need to be committed to an institution. And all shades of grey in between.
Here's some kinda amusing sounding stuff -
A few years back Sy and another poster analyzed and tested some C37 and PK, and the other poster wrote the following:
All this research now needs to be started over, as EnABL technology completely swamps what either of these 2 do on their own (the conformal )micro-gloss) post-coating accomplishing a similar effect to the C37 or PK), and now it is a matter of whether a pre-coat of either of these benefits the sonics after EnABLing.
I didn't know Sy was an EnAbL-phile. Snakes alive!
Better, if at the wrong level. My preference would be prefer 3-phase. The picture discussed though was nature of the waveform from a wall outlet and the naive believe utilities still provide nice, clean 60 Hz sine waves. In more troublesome situations driving nasty industrial loads I've seen waveforms approaching a triangle.
All the easier to filter in the raw supply. The trouble comes in with RF, where power supply caps aren't as effective and the use of toroids exacerbates things, but that's why Mouser sells Corcom filters. What people believe or don't believe about AC power is less relevant than what happens at the DC end. The idea that "pure" 60Hz is desirable is a curious one.
... but that's why Mouser sells Corcom filters.
Nice devices and I'm not in the camp which believes they 'steal life'. As to the consequences of rectifying wide band, low frequency input noise, I've never analysed it. Seems to me it would have more impact on inter-chassis ground currents than on the B+, possibly explaining why some like the sound of high galvanic isolation.
Because some of us read that in Stereophile that you need to get the incoming AC all cleaned up and looking purty, or so said the seller in said mag...
And I accepted it...hook, line, sinker...barf... :headbash:
I really used to take Stereophile for granted. and why? because they published graphs. and then they go on and say "but they don't mean a thing". it took a while to realize they're the typical buffoons, just wearing slightly different clothes.
A hard core 'objectivist' ignoring clear measurements in favour of personal perception, who humorously insists the standard SLA of big city utilities will be changed by complaining... it must be Friday.
Gosh you sure have a snarky tone in your replies. Get more sleep before you reply next time.
Please read the following: Power Line Noise
More specifically what's in II and III.
Interference: Defining the Source | FCC.gov
Those concern noise only. Have you raised any concerns to your utility company about the voltage fluctuating? If not then I don't won't to hear anymore from yourself about it. Seriously if you haven't even tried then stop complaining to me and start complaining to them.
I clearly stated about the filters that there are lots more to be found online so do your own research.
Yeah it's funny how this "objectivist" actually used a real life situation where I measured the voltage at a steady 123 volts and zero noise on the line 🙄 I'll try to be more grouchy next time and rant about my "poor" electric power so you won't feel left out. The bottom line for me is that I NEVER hear any affects from my AC power in my audio components and that's good enough for me.
