Amplificator Class A 2 X EL504
hello ,
i me stocked 2 tubes EL 504 for build amplificator 2 ways to EL504 .
i research montage to single ended ( for use 2 ways ) ?
i me research to Google.com , not good research completed to value schématic and spécification 🙁
sorry , me english is bad 🙄 .
http://www.diyaudio.com/forums/attachment.php?attachmentid=341336&stc=1&d=1365447815
me tested basic montage to 1 EL 504 to 34 V - 6.3 V 🙁 , not possible test , so possible error ?
hello ,
me build is stop it 🙁
so me transformator is very little for good use power , no probleme , the " solution " , HT to 180 V= is downgrade to good 90 V= 😉
me news build to short listing matérial .
2 PL 504 for connected to left and right to 90 V= , use 24 V~ to filament .
me power to 8 Ohms , is very little 😛 , use 0.0.. Watts RMS !!!
so not problem , is not drive installed for test .
me montage to screen 😉 .
slow build is good appréciate to search link for build .
me first build , i me newbie , no problem , so looking build for up me good build .
bye all 😉
ps : me test to video ...
2 PL 504 en stéreo - 80 V= - Vidéo Dailymotion
hello all ,
a stable version with my new transformer, j has to re-modify my assembly(editing) for obtenri moves forward badly because I am not good at arithmetic complex, me the power of mwatts 500, him(it) takes(brings) out in 2 x 8 ohms, have there some more of work has to make put the assembly(editing) is stable and he(it) have there not of 12 AX 7 d to use in l imédiat.
Has bientot
hello ,
the build is upgrad for the test , the graphic is news .
and transformator " impédance " is 225 Ohms primary to 2 Ohms secondary ; me use 8 Ohms to speaker , not saturate voice !
no problem , so test for upgrad me build , only , no build transformator adapted .
tks 😉
hello All ,
me project to amplificator 2 X EL/PL 504 is stopped !
i me very dificulte problem to calculate curve charge and excursion for use 12 AX 7 / ECC 83 .
the project is std-by and news project to use ECL 805 is créate ( copy to base ECL 86 ) .
the schéma for news build ... so éasy build , me juste change component for test and use .
me test is good and me ajusted to test power to news project ...
4.16 W rms to 6 ohms impédance HP so 1 Khz , litle problem for max power !
many thanks for all , good day
Jean Michelle, choisi un vrai transformateur de sorti aproprie pour ta lampe avec simple PL504.. N'est pas possible a reussi avec trafo d'alimentation..
Translated: Choose a real output transformer appropriate for the single tube PL504. Not possible to succeed with power transformer.
My French is soooo rusty..
1k:8-ohm
185v power
Gate voltage-20v, anode-to-cathode voltage of about 165v, the load curve.If the impedance can be selected such that it is indeed the best. I use 3.5k-ohm, 285v out of frustration, just have these hands, and watched the curve pretty good, but some of the output power is small,only2.6W.
hello ,
many thanks , so me English is bad ... lol 😀
it is possible use Transformator " Torique " or not EI ?
me possible use transformator torique to 230 V ac and 2 x 6 V dc for use EL /PL 504 !
Or then I to find custom-made transformer?
tks for all 😉
