FET-hex explendit amplifier
For bias stability with irf/irfp version the best is to use n-channel mosfet in biasing ciruit.
With bd139 bias from cold 100mA is dropping to around 60-70mA when hot but with eg. irf840 (in my case) bias for o/p transistors is rock solid in wide temerature range.
Also I am not sure if the source resistors for one pair o/p transistors (irfp240/9140) are required - I am running amp without them and everythink looks just fine.
I built the version 3.1
As Borys said the bias is rock solid. After 20 min since turn-on power bias is stabilising on around 98mA and for 3h is still 98mA. All the time.
I listen little time and I must said, that is rather retail or realistic sound, not "lovely" , "sweet" sound.
Sanken unit and 2sc4793/2sa1837 arrived this morning
next to follow...
Hi All!
I made my own lay-out based on VSSA BJT by Borys. I'm kind of liking the BJT version for the reason of parts availability. I have made the input pair to be 2SC2240/A970 and the CCS to be 2SC1845/A992. These types are very much available here in my place. My lay-out is not final, not till Borys (or somebody who has the skill) will post results of a stable VSSA BJT version. Sorry I do not have the skill to properly test this amp.
Best Regards!
Hi All!
Best Regards!
These could be an option for higher power version as Vceo rated at 120V and HFE BL rank at 300-700...
Marc
