new Renardson amp
I have simulated the output and would like to discuss it regardless of John Curl opinion:
”This fellow Renardson, is amazing! He re-invents all of audio circuitry, and then says that high power is not needed in the home”.
Here are simulation results with R8 stepping from 100 to 1000 Ohm,
- transfer function of the output stage,
- current through nonswitching negative (lower) output device,
- transconductance of the output stage, please note the excellent linearity
Sorry for my slip,
instead "current through nonswitching negative (lower) output device"
please read "current through nonswitching positive (upper) output device"
Pavel, yes, it is uC7, I have not tried harmonic analysis, don't trust simulators... But it is not a problem
I got several comments from the board members that the amp will have low disto only with active load, and with reactive loads it will be the same as ordinary class B.
Now Mr Renardson checked the 20kHz distortion with a parallel capacitance, and added the result to the test page. The distortion was higher than before, but the load impedance is lower, so some increase was expected, but there is no serious crossover problem.
Reminds me of the bias circuit for the A40.
this one ?
https://www.firstwatt.com/pdf/art_a40.pdf
And another amp based on the same principles from Czech
Neexistujici domena - Webzdarma.cz | Webzdarma.cz
URL is dead - go to
Zesilova? s korekc? p?echodov?ho zkreslen?
https://web.archive.org/web/20040409233632/http://petrh.czweb.org/images/renardson/renardson.gif
I am looking for commercial amplifier brands, who use this approaches.
