Precision Devices PD.2450 in OB, or alternatives ?
Two 24" woofers is approx the same cone area as eight 12". You will gain nothing.
It is more effective to just increase the baffle size than go brute-force with cone area. Doubling the effective path length gives you 6 dB better efficiency and max SPL.
But anyhow... you need massive cone area if you want to play loud at low frequencies. Trust me - I have sixteen 21" in large H-baffles, and it's not sufficient at 20 Hz....
StigErik, I know your system, it's one of my favourites! I am aware that Sd is similar however PD has larger Xmax and therefore it should pump larger volumes of air with lower distortion. I don't want to increase the size of my H-baffles since it will colour the sound. Maybe the solution is to utilize more H-baffles with same loudspeakers I have now? Advantage of these woofers is very low price which is however a result of a steel frame...
some of the distortion you are hearing can be the resonance of the h frames you have.
before spending more $$$, why don't you try to improve what you have in hand?
- as a start, you can try stig's bicycle tire tube method under your h frames
- you can add a horizontal brace between side walls
- and add some mass (sand bag, concrete/marble slab etc.)
- you can also try magnet mounting or swinging the drivers if you are not too attached to your H frames
My H-bafles are on loudspeaker legs, so the "tire tube method" is impossible to use... Nevertheless these legs helped A LOT!
So, since I have what have, I start to convince myself to:
- increase the amount of these H-baffles with the same speakers I have
- dampen the steel frames of these woofers (with bitumen mat or/and duct seal, which I already tried in other system)
- make a brace between the sides (which I was also thinking of before)
I also think about adding some damping mass to these baffles but I did not figure how to do it acoustically good and WAF good (which BTW is really high 🙂 ).
And, since loudspeakers are steel frame, I think it is not good idea to make them baffleless (swinging or magnet mounting). Being attached to the magnet the diaphragm, with help of the upper suspension, would "move" the frame and even increase the distortions. What do you think?
BTW. Thanks for the help!
18" Faitals delivered today.
all i can say is they are very light for a 18" driver.
very well made though.
i will use them with a 12" Faital mid and B&G neo8s tweeter in a 3 way swinging nude dipole project.
sorry for the hijack grimskull...
i think it is time for you to order some grill cloth for WAF
