What the heck? It's less than lunch!
Cool. Nice idea!
Still very happy with my lunch money amp. It's now housed with a USB/MP3 player with FM tuner and it all works very nicely. This module was hopeless with a class D amp as the high speed switching caused interference on FM drowning out all but the strongest stations.
Cool idea! I like it!
Mark
. . . I still cannot get over how good this amp sounds, and it must sound good, none of the modders have made recommendations.😛
Actually, there is one: Linear regulated power.
That's just a bit more fresh. Perhaps overkill. 🙂
However an audio amplifier is this: Power + signal = output.
Energy from small signal is tiny, and that means the largest input is, in fact, power. So, good quality power means a lot.
See LM338 datasheet schematic for "Tracking pre-regulator" colloquially termed Nested Regs. That sort is really high end, at minimal complexity, minimal cost, and almost a well kept secret. It seems a good partner to this amp. Somehow, this particular amp, with a very good 8 watts and headroom to 16 watts, tends to make overkill on quality, a lot more fun than usual. In most conditions, it easily beats the T-amp for quality, but if we want to make really sure of that (or just make it really obvious), then linear regulated power is the way to go.
I'm willing to give this a try, not a lot of money and useful for other little projects.
Another amp finds a permanent home...
Hi there,
Great thread!
My amp arrived the other day. Hooked it up and found that one channel was much louder than the other. I suspected the volume pot was the culprit, and after some deoxit, still the same problem.
After replacing the volume pot with another I had on hand, the amp was finally playing at equal volume across both channels.
... and I was impressed with what I was hearing.
I found a $3 wooden toothbrush holder, and thought it might be a good fit as an enclosure for the amp. Ended up being an perfect fit, with a little bit of clearance to allow for the wires to pass over the heatsink.
I removed the bottom of the toothbrush holder (since the wood was too thick to be used for mounting binding posts, etc.), and replaced it with a square piece of plastic (I cut it from the enclosure of an old wifi router from the junk box). Attached some binding posts, a 3.5mm stereo input socket, and a standard 12V power socket.
As you can see, it's a tight squeeze in there. Might drill out some holes for ventilation. Also, need to add a panel to the front, maybe something translucent, and then I'll add a power switch.
BTW, at higher volumes, there is an audible hum. Any ideas on what it could be and how to resolve?
There was another hum that would occur when touching the volume pot, but I got rid of that by grounding the case of the pot.
Pete
That might be the sound of a ground loop. A ground loop happens any time something has been grounded more than once.
Do you have a grounded source such as a computer?
Does your amplifier's power supply have a 3 prong plug or is a double-insulated power supply with a 2 prong plug?
Hi there,
Great thread!
Pete
Very neat job! 🙂
Hi again,
Thanks for the comments. I tried to keep the project as neat as possible since the amp will be sitting in our study on the desk, so there's a bit of FAF involved (family acceptance factor).
It's funny when you get more and more into this hobby and you start noticing potential enclosures in all shapes and sizes 🙂
Daniel, the power supply (SMPS) I have has a 3 prong plug. The amp is connected to the laptop via an Edirol USB audio interface. I found that the hum only really kicks in when the volume pot is turned up to about 80 or 90% of its range. Since it's a linear 100k pot, I guess that level is really out of the listenable range. Could it be a faulty pot? In any case, I will try adding some resistors between the pot's pins, to turn it into a more of a log pot. Currently, the volume pot is not very useful since there is such a fine line between quiet and loud, as some people here noticed with the original pot.
Cheers.
Hi again,
Cheers.
Could be your laptop? my laptop produces a slight hum when either asleep or off.
I have a selector box connected to my laptop, cd player, fm tuner and minidisc player. The laptop is the only component that produces this hum, but not when running. Try connecting your amp to another component.
At my usual listening level with the laptop in sleep mode, the room has to be quiet and my sitting close to a speaker for me to hear the hum.
Hey Guys,
I've been using one of a "Mini Amplifier Board 10W+10W Class D Amplifier 12V"
http://www.ebay.com.au/itm/280917627145?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
but even with ferite cores on the speakers, it just gives to much feedback, buzzing at idle and interfers with my FM radio. So i've put the money down for a
TDA7297F Amplike everyone seems to have here.
I am going to de-solder the Volume pot add some wire and move it to another location on the case, Is there any way i can introduce an Of//On switch to this?
Also any other tips from existing users?
Cheers Rob.
Almost. Pin 7 needs to be >1V to put the chip in standby mode. Have a look at the datasheet, though. You'll probably want the RC delay on pin 7 to avoid turn-on thump. A small current-limiting resistor in series with the switch, placed in parallel with the capacitor, should work.
is that little FM tuner STEREO?
I have since purchased a 3116 board plus a 2.1 deluxe version but have swopped back to the 7297, it just sounds so much better on my setup, and not just FM.
Time to take the 7297 seriously and house it.
I have a spare RS Minimus-7 speaker and I'm thinking that if I remove the guts and use the aluminium box to house the 7297 and a small FM tuner, as pictured, it would look smart?
I have given up with D-amps, just too much RF interference.
There are some interesting discussions on the web about d-amp car radios and interference.
