which DIY amps free of turn on/off thump?
I thought this would be a useful thing to know, for people who are, like I have become, fed up with turn-on/off noises. I know a speaker protection relay will also be a solution, but I would also like to know which amps are by-design, free of such problems (unless caused by bad power supply design). Can you share your experience ?
As far as I am aware:
No turn-on thump: no. 2, 3, 7 & 8 are symmetrical amps
1/ Symasym (Mike Bitner) http://www.lf-pro.net/mbittner/Sym5_Webpage/symasym5_3.html
2/ Leach - make sure psu caps have bleeder resitors http://www.diyaudio.com/forums/solid-state/74962-leach-amp-turn-thump.html
3/ VSSA (Lazy Cat) http://www.diyaudio.com/forums/vendors-bazaar/225747-vssa-lateral-mosfet-amplifier.html
4/ FC-100 (Roender) http://www.diyaudio.com/forums/solid-state/111756-rmi-fc100-single-stage-audio-power-amplifier.html
5/ Circlophone (Elvee) http://www.diyaudio.com/forums/solid-state/189599-my-little-cheap-circlophone.html
6/ Moscode (Mr. Moscode) - if build right version http://www.diyaudio.com/forums/tubes-valves/95240-moscode-600-hum-turn-off-thump.html
7/ Pass F5 (The One and Only)
8/ Ovation SX-Amp (Bonsia) http://hifisonix.com/
9/ Dynaco 120 (with Dan's mods) - http://www.diyaudio.com/forums/solid-state/156627-dynaco-stereo-120-can-beautiful.html
10/ TGM7 (based on Greg Ball SKA GB150) http://www.diyaudio.com/forums/solid-state/239418-tgm7-amplifier-based-greg-ball-ska.html
Does have turn-on thump but might be minor: so far none of these amps are symmetrical
1/ TGM1, TGM2 (my own) - minor but present (true for most bootstrap VAS amps)
2/ TGM3 (my own) - single transistor dc-servo takes time to settle
3/ Fetzilla (Hugh Dean, Greg Peters, Lineup & Mikelm)- minor http://www.diyaudio.com/forums/aksa/191053-swordfishy-aspen-fetzilla-power-amp.html
4/ DX (Carlos the Destroyer) http://www.diyaudio.com/forums/solid-state/96237-destroyer-x-amplifier-dx-amp-my-amplifier.html
5/ Akitika GT-101 (Dan Joffe - has commercial interest in selling kits; "small click on start up") https://www.akitika.com
6/ MJR7-Mk5 (Renardson) "just a small unobtrusive sound" http://www.renardson-audio.com/mjr7-mk5.html
7/ P3a (Rod Elliot - commercial interest - sells pcb's) PMI says "small 'click'' designer says "minimum 'switch on' or 'switch off' http://sound.westhost.com/project3a.htm
8/ TGM8 (inspired by P3A) but pcb has speaker protection on board with delay so no turn-on thump in practice http://www.diyaudio.com/forums/solid-state/245619-tgm8-amplifier-based-rod-elliot-p3a.html
Edit: I'm referring here to DIY amps that we can build ourselves - so schematics and other necessary details are freely available. I'm not so much trying to capture information on commercial amps or kits.
Hi Bigun,
I think you can put the VSSA (the PeeCeeBee version for sure) on the list of nice quiet amplifiers during turn on / off. I don't find there to be any noise or discernable cone movement during the transition from off to on or on to off.
I never experienced any thumps from any amplifiers I've built even simple chipamps, few times I had turn off thump, which was cured by paralleling mains switch with small value X1 capacitor. That includes modified Pass F4, Citation 12, LME49830 based amp, Elvee's Circlophone and others with no specific names. I haven't used any pre-made PCB's, so I cannot comment on that, as layout is really important.
I built a class d 2092 based amplifier.
On power down I would either gets huge thumps or a siren type noise.
I found it was due to having very large power supply capacitors causing the discharge to be very slow and upset the 2092.
I found the only way around was to add a small PIC based circuit which monitored VCC and held the 2092 in reset if the voltage got less than 15 volts.
I talked to IR about it and they said it was a rare problem and I had done the right thing to fix it.
Simulated thump of Gaborbela s 20 years old amp
modded as in the relevant thread , version with BJTs.
what can you add to these lists ? - what about P3A...
No thump (tested).
Strictly speaking, not a "free" design, because the schematic for the board is copyright protected and not available to be published, you only get it when you purchase a set of boards from the designer. However, it IS diy, and quite simple to assemble and test.
