The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.)
Hi.
I thought it would be interesting to show my pcb to others, hear opinions, etc.
After failed search for LM4766 pcb on internet, i decided to route myself. Because all pcb's i found on net was really bad...
I need to say, that i don't believe in expensive parts.
Only thing i care - no ceramics or electrolytics in signal path.
This PCB uses three stages of power supply bypassing:
1. 2x2200uF
2. 3x22uF
3. 3x0.22uF (smd)
Bypassing scheme based on LM4780 datasheet :)
input bias resistor to gnd 47K
input resistor 1K
input capacitor 0.68uF (-3db at 5Hz)
feedback 4k7 and 47K (smd) gives gain of 11
feedback caps 100uF
zobel 4r7 and 0.1uF
mute resistor 8k2 (smd) pulls about 2mA, 1mA per ch.
signal ground separated from power with 3r3
All smd 0805.
Amp sounds awesome, very strong and accurate bass and clean highs.
Probably a little better than my LM1875, which runs down to 1.5Hz what is too low on my poor small test speakers. But with normal speakers everything probably be different.
This LM4766 pcb is interchangeable with my LM1875 PCB, so i tested it with same power supply that my LM1875 uses (8 x mbr340 and 6x2200uF)
I going to try bi-amping with LM4766 to 310hz, and from 310hz with 6P15P tube amp.
Tube amp is tested and works really nice
And later i will post photos of almost finished LM1875 amp. < EDIT. No i will not post LM1875 photos here. It would become messy. I dedicate this topic to my LM4766 - 6p15p BiAmp.
If someone copy my layout, would be nice if you let me know. Or even show a photo if you build something with it :)
Pretty cool! I was not finding much on people having used the LM4766 too, while looking at the various Overture chips on the Digikey page. Glad to hear something good about it. I might try to configure it for current drive on small fullrange drivers if I go with this project.
IG
IG
Thanks. I will post more pictures when i make some progress.
What advantage current drive have?
And i allmost forgot to mention: In my experience all chip amps hate high gains. I think gain of 11 is optimum, because with every bit of aditional gain chips sound worse, so i like to set gain just a little higher than minimum recommended and use preamp.
Yes, I'd like to hear about current drive as well, I am using LM3886, and although it measures worse, is not so linear, I love the sonics of that amplifier driven by tube preamp.
Actually i don't use tube preamp. My active crossover have some gain in this case.
I tested crossover with one channel of LM4766 conected to high frequency output, and other channel to low freq output. In other words bi-amping.
And it sounded really good.
Now i need to make power supply for tube amp. Then i will be able to test bi-amping with tube amp for highs and 4766 for low frequencies.
I guess that is the most important part, if it sounds good to you, then it is good.
Measurements often do not correlate with how appealing the sound of amp is. Maybe due to non-linearity of speakers or something. I'd like to get some info about crossovers for current driven speakers.
Good luck with tube amp.
Very good one. Very clear power and signal ground. Much better than most ebay PCB, where even double side PCBs do not have clear signal flows.
If this PCB does not have good sound, it must be the chip's fault.
Thank you for good words :)
P.S. Project is not freezed, but my camera and/or memory card died... And
project is in my grandparents village... So when i go there i will take pictures.
Now box is half made. And most of pcb's mounted.
Amp tested...
And sounds awesome.
Need to make:
1) Control PCB with:
*ON/OF using pushbutton
*Fan based on temperature
*Delayed B+ transformer
*Maybe something more...
2) USB port for charging (have 5V st-by supply anyways, so why not :) And i like to use smart phone as music player...
3) Cover
4) Something i forgot to mention lol
If someone ask why i'm making it so complex: I do this not only for music, but for learning purposes, because I'm 18 years old. I like electronics not only music :) And try to make something new every time, to learn new things. This year i'm going to university to study electronics engineering.
Photos:
Can i have the .PCB file of the PCB?
I want to use your design but add few tweaks and replace my previous amp board that i bought from ebay, rubbish design. not too bad but still...
You can use this design and share it, remake it or do whatever you want, if you want :D
The bass is weak and muddy... But it sounds horrible compared to this :
  • New WinRAR ZIP archive.zip
You can use my design.
I hope that i succesfully attached the files...
Hello,
Project BiAmp is fully finished now. It now have PCB with some transistors and RC delays to start transformers in needed order, and to hold tube heaters and fan some time after turn off. If someone needs it, i will post schematic of the delay circuit. But it is realy straight forward.
Recently i done last tweaks and mods, including cooling upgrade with very quiet fan. Now it is practicaly completely silent from listening position.
About LM1875. It is not completed, and i decided not to post anything of it in this thread. I stopped that project, at least for now.
Now few photos of BiAmp:
Before mods:
http://i.xomf.com/cbfbw.jpg
After:
http://i.xomf.com/pvrcd.jpg
Completed, only cover missing:
http://i.xomf.com/xpwbn.jpg
All photos of modification process in youtube video:
https://www.youtube.com/watch?v=4mxrTyLRmpY
Don't mind music. Had to use non copyright stuff.
Ohh, I did get it working after I changed those SMD caps... They were low voltage ones and they both pretty much blew up but I didnt see that and even close inspection didn't give me much to see... But I changed them for 50V ones that are actually very common.
Cool project tho! :D
