Maybe this is a bad timing
but it would be really great if there was a board that accepted both SPDIF and I2S with a relay switch to choose between the two.
A single board might be nice to have but you can realize this with an SPDIF Receiver (e.g. TP SPDIF Transeiver Module) + I2S MUX (e.g. TP Otto II) + I2S DAC.
Yes, switching SPDIF/I2S could be done using Otto II.
But there is no relay on this board...
It's a digital switch, don't know which IC is used to do the job.
From what I've seen it performs quite well.
I know of the twistedpear boards. But this solution would be quite expensive (around 100$ extra) and the tranceiver board is out of stock since forever.
Actually I was half joking. But only half, maybe there is real interest for this from others and there will be a surprise third BCB 🙂
EDIT:
after thinking about it for a second, a board with switch would actually make the other two single boards redundant...
We choose for the best solution either with SPDIF or I2S. A relay is no option. If one wants features then our DACs are not the right choice. We design purely for audio quality. I can not make it any clearer but we did drop the U.FL on this board with a reason as explained before. We try to finish the second version so please give us some time (again).
@jean-paul Thanks for being candid and honest. I can't wait for the i2s U.FL version of this project and will wait as long as it takes.
@jean-paul, the last several post's might not indicate it, but we are several 100 who really appreciate your work, and Don’ts want anything haste through on the expense of sound quality.
Thanks for a very very interesting project Jean..
Thanks, final V3 SE SPDIF version is with Subbu now for his approval. Some things changed for the better and still some details are being discussed. I think it is a worthy successor to V2.6.
Focus is now on getting the other version ready.
JP,
That a thumb up!
If the SPDIF version is approved; are you going to send it a PCB manufacturer? ...or are you going to wait for all the versions to be completed/ approved?
That is up to Subbu and possible sub-distributors to decide.
I suppose it is better to have the SPDIF PCB shown, then wait for the orders and payments done and then have that board produced.
On the first page of this thread you can find the links for google sheets. Put your name there.
Final version of Subbu DAC V3 SE SPDIF has been approved, the Master of DACs (Subbu) will announce it but I spoil the party by being just a bit quicker 😉
Some features to warm up the SPDIF aficionados:
- As said before: no U.FL as it is meant to squeeze the max out of our beloved (cough) SPDIF interface...
- better layout for C32
- Molex KK connectors
- More pads for experimenting with caps
- Vias to the GND plane for experimenting with shielding the charge pump area (untested but costs nothing to add so feel free to try it out and report your results)
- decoupling caps closer to the DAC power supply pins
- introducing headache: one (1) 0603 cap....
- better footprint for the resistor array
- larger footprint for the 100 µF caps
- possibility for using 5 x 3 mm XO's
No breathtaking hardware differences with V2.6 but that was to be expected. The V3 beta already performs better than V2.6. The power supply PCB has been changed slightly (through hole diode bridge, higher current capability) but it has not yet been approved. I want to apologize for the long waiting and I hope it was worth the waiting. I think it is.
Since when does "other" version translate to "USB" version ? 🙂
I changed my row in the spreadsheet to zeros, as I'd prefer to wait for a USB version.
Will there be a heads-up concerning the end of the GB so that us fence sitters have a chance for decision making?
You are not telling me to delay things any further do you ? 😉
My advice is to not sit on the fence, there has been plenty of time (seas of time would be a better phrase) and we want to have the PCBs ordered, paid for and then produced. Fence sitters always are the guys that ask for products when they're not available anymore and that habit comes with much emailing. It is really more relaxing to try things out, besides that the cost of this DAC is low. If you decide now you can not really be accused of being a risk taking "early adopter" 😀
Not trying to convince you but the earlier boards were quite popular as I later even saw ads of people asking for them. Chances are likely that you can simply just buy one (no need for a fence) and sell it later when you make yet another tough decision of selling it. Really, we got more requests for V2.6 boards after they were sold than when they were available. That won't be different now. We gave in and promised a V3 which arrived finally but there won't be any follow up except for "the other version".
No V4 folks ! If you want an SPDIF version this is the chance to get one.
JP, I think if you don't have a "Certified Counselor" plaque on your wall, you will deserve one by the time this GB is complete. 😉 I have a few non audio incrosyncities you may be able to cure when you have some free time 😀 😀
- Group Buys
- ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
