The presently MC prepre of the Pearl phono stage (configured as high input impedance common emitter line stage with input at gate of the j-FET) is the ideal choice for MC cartridges with internal coil resistance above 100 ohms. If I have a internal coil resistance arround 15 until 40 ohms (like some models of Lyra and Audio Technica) I get better results (more tight and clear so as more sonic dymanics) with line stages in common base topology like Hiragas prepre, see
Hiraga MC Preamp
or the Mark Levinson JC1 (see pdf schematic)
what could be the reason for this?
Hiraga MC Preamp
Disagreed. Even with low impedance sources, the Ono/XP-15 is one of the quietest phono preamps I have had my hands on.
The Hiraga circuit is a great sounding classic. Not so sure about the JC1 with the 1000uF at input.
If noise is not an issue i would take a single resistor loaded common cathode fet (or even better - a triode) instead of the Pearl arrangement.
You haven’t understand my question.Disagreed. Even with low impedance sources, the Ono/XP-15 is one of the quietest phono preamps I have had my hands on.
Additional I don’t know about the phono preamp “ONO/XP-15”
I know only the models
- “Aleph ONO”
- “X-ONO” (successor Aleph ONO)
- “XP-15” (currently available and successor for “X-ONO”)
Maybe you mean one of this models.
The Pearl Phono stage (not a commercial product)
http://www.passdiy.com/pdf/pearlphono.pdf
use as MC prepre a line stage in common emitter resp. source topology, i. e., a voltage controlled input. For me it is definitely clear, that MC prepre versions, which use a common base topology, that means current control input (unfortunately, very few commercial models), give better sonic quality by MC cartridges with low internal coil impedance (but I don’t know, why; and a possibility for configuration to both topologies it would be very helpful).
Because I haven’t schematic of all three mentioned models, I will not rule out, that one of the above Pass models use a prepre topology which use a common base topology (because one of the earlier preamp model of master developer Nelson Pass uses also a common base respective gate topology – see PDF file at bottom). Perhaps this is the reason of your statement.
The type number “ONO/XP-15” is total unknown for me – please send me a weblink about this, if it should really exist.
The Pearl is intended to be used with MM or high ouput MC cartridges, not with classical MC cartridges. Despite from the fact that the input stage is far from optimal for MCs (you are right on that one), overall gain is a little low for MCs.The Pearl Phono stage (not a commercial product)
use as MC prepre a line stage in common emitter resp. source topology...
even tube amplifiers with such topologies (GND-GRID) like that one from post #1 are present - go to the schematics from follow URL:
Teflon coupling capacitors & More No-Gain—No-Pain Tube Buffer Circuits
I know only this commercial products:
1) Audio Space Reference Two phono preamp and line stage amplifier
SoundStage! Equipment Review - Audio Space Reference Two Preamplifier (4/2008)
Audio Space Reference 2 Linestage Preamplifier | The Absolute Sound
2) Audio Research MCP33
http://www.diyaudio.com/forums/tubes-valves/10635-audio-research-mcp-33-a.html (go to post #4 for schematics)
REFERENCE COMPONENTS-MOVING COIL STEP-UP DEVICES
Who knows additional brands and models for MC step-up pre-preamps in this kind ?
Just build a Paradise and be done with it. silent and with lots of gain.
Are boards for Paradise available on-demand, or do you still have to wait for the next potential group buy?
This is a thread about common base stages :
http://www.diyaudio.com/forums/analogue-source/195017-jg-s-nobrainer-nobrainer-discrete.html
Which model you mean? The CA-5A ?Didn't Nelson's preamp for Nakamichi have a common-base FET input for the MC stage?
Nakamichi CA-5 E II / CA-5 A II / CA-5 II Bedienungsanleitung Vorverstärker Nakamichi Bedienungsanleitungen Hifi-Literatur kaufen - Spring Air Second Hand HiFi Shop
A nice vintage preamp? - AudioKarma.org Home Audio Stereo Discussion Forums
http://www.diyaudio.com/forums/parts/223548-parts-nakamichi-ca-5-a.html
Download the Nakamichi CA-5-A Mk2 owners manual for free - Hifi Manuals
Thank you very much for this advice.This is a thread about common base stages :
Wouldn't the emitter current of all those common-base pre-pres overload the cartridge coil wires while flowing trough them? Or at least produce some distortion while interfering with the magnetic field?
check out this:Wouldn't the emitter current of all those common-base pre-pres overload the cartridge coil wires while flowing trough them? Or at least produce some distortion while interfering with the magnetic field?
http://www.diyaudio.com/forums/analogue-source/229794-allowable-dc-current-phono-cartridge.html
http://www.diyaudio.com/forums/anal...-much-error-voltage-before-coil-damaging.html
check out also post 17 about
http://www.diyaudio.com/forums/tubes-valves/10635-audio-research-mcp-33-a-2.html
Current domain MC-pre
Is this what you asked for ? 🙂
AQVOX Phono2CI
Dynavector pha200 (discontinued)
Dynavector p75mk2
Bmc-audio bmc-phono-mcci-30
And the most famous of all:
The Phonocube
...of which the Phonoclone is inspired
DIYA Phonoclone page
If this was'nt what you asked for, I blame my bad english 😀
AQVOX Phono2CI
Dynavector p75mk2
The Phonocube
Any news?The presently MC prepre of the Pearl phono stage (configured as high input impedance common emitter line stage with input at gate of the j-FET) is the ideal choice for MC cartridges with internal coil resistance above 100 ohms. If I have a internal coil resistance arround 15 until 40 ohms (like some models of Lyra and Audio Technica) I get better results (more tight and clear so as more sonic dymanics) with line stages in common base topology like Hiragas prepre, see
Hiraga MC Preamp
- Better MC Pre-Pre solution for low internal coil resistance- not only for Pearl phono
