What do you think..OP Tx
Look at the physical size and then ask yourself, how much sound can go through a transformer that is not much bigger than a 12AX7.
I have an older set from the same manufacturer that doesn't have the 8K tap. They work for the intended application, a cranked guitar amp with a small speaker, not much else.
If you are going to get OPT's from the US, get the Edcor XSE15-8-5K, they will blow those little "Champs" away in a HiFi application. For 2 or 3 watts they are great. I use a set in a SE trioded 6V6GT. Juts about right. Saturation sets in when you plug in a KT88 and ask for 8 watts.
Anything from the USA has become uneconomic due to postage and import duties.
It is better to source from EU countries ie Valves Stuff or RITTER electronic systems--Die Röhrenspezialisten seit 30 Jahren! - these are good BUT be aware that they will only accept payment via IBAN. A general problem in Germany.
A good site that accepts PayPal is Tube-Town - Hot Stuff cool sounds - excellent service
Cheers
John
Hi Cookj ! I was having a look to this RITTER electronic systems, and they sell output transformers at very good prices, but i dont know the quality of this transfos ! Did you ever tested one of those ? Can you tell me something about the quality ? Thanks
Just for interest..
M. Gregg
Well,
after looking at a few other makes of OP Tx...edcor has better low frequency..I'll use Hammond mains..(Keep the weight down)
Then whats in the box ?(rectifier) 5y3...It can be used horizontal if the pins 2/4 are vertical...I'll try and get it upright...
NB its an all valves/Tx's mounted in the box build I hope.. 🙂
A couple of Mullard EF86 (Paint missing from a quick wash) should last about 35seconds to 20 years dependant upon power up..😀 Sylvania 5Y3..about the same..😀 (Then again the 5Y3 is new so maybe it will last a bit longer)
M. Gregg
Some parts,
Arrived today...
I had to try the strange red astron just to find out what tin sounds like..😀
I have some same value jensens and others to try for fun..
Tx's on order..Hammond mains, edcor output..
Suppose I will have to do some more on it now..🙄
M. Gregg
More from the snail...:snail:
Power Tx arrived..
Its big enough to mod if I want to...hopefully it will run cool/quiet..:xfingers:
Vent holes drilled in base plate..
Just thinking about bases for the EF86's..I will use shrouded then I have the choice to use screening cans..I like the phenolic..But I'll get both. 😀
M. Gregg
Some more....:snail:
Started to build the input selector board.
Waiting for some more parts.
Just thinking about some mundorf tubecaps...however I have to wait for the OP Tx's from Edcor to check the space available.
M. Gregg
Selector card completed,
I have some anti vibration mounts for the circuit board.
:snail: <<<still fitting it in...🙂 so its a bit slow..
I don't want to use PCB tracks so its silver wire link.
M. Gregg
