Photo Gallery
Just finished up a special Bottlehead Crack build I call the Coppermine Crack. This build took a bit of work: I mitered and routed the wood base, then copper leafed it, which is a fun experience if you haven't tried it. The plate of the amp is 12" x 12" x 0.1" copper. Some changes from the stock build are the 6SN7 signal tube, the excessive use of film caps for power and coupling, and a pair of oversized chokes. Hope you enjoy the pics.
For a detailed rundown of the build and more pics, visit:
DIY Audio Electronics from Zynsonix.com: Bottlehead Crack Coppermine Edition
Hi guys. My first headphone amp
That looked cool!
Either the tubes are big or the box small, so please let us know - what tubes have you been using?
After redoing the guts of my 5998A-SE and swapped to a big and yellow knob it looked like this. Got an 5998A-PSE on the way.
The marks around the ECC81 was done by the alu-ring (similar to the one around 5998A), but the socket was a bad apple and the new one didn't mach the ring.😡
(I have started to name my projects after Russian cities)
My latest amp.
ECL86 SE mono amp. Built in one day. I've been away from SE amps for a while, got tired of them. On my 43th birthday nostalgia kicked in (my first amp was a PCL86 SE) so I built this to rememorate past feelings. Turns out I love its sound.. Haha, audio is a neverending story. Special features: UL, no cathode caps, last filter cap is a big Solen poly.
Yes to build an amp in day is a real challenge. I have done it but had everything primed and ready to assemble. I'm a SE nut and lately moving back to SE ULs. I built one whole amp PS totally with Mundorf M-caps (polis) in the PS. Big and expensive but I feel it did add a special edge to the sound.
