Joachim Gerhard Filter Buffer for ES9022
@billyk I'm thinking of doing something very similar... pretty much exactly the same without the re-clocker board just the isolator. Do you think the Subbu v3 power supply can supply the Amanero as well as the Acko board or are you just going to use bus power from your cpu for the Amanero?
This is way off topic, but this is not a great idea.
The supplies for either side of the isolator must be independent for the isolator to function. The DAC + isolated side of the isolator chip can be from the same pre-regulator.
I use bus power for my Amanero with Acko's isolator/reclocker board (only isol, for now).
I've assembled my JG Filter, just need to find time to hook it up now!
Dispatching parcels
Thank you all for your patience.
The parcels are ready to go. 🙂
WK
WK,
Do you have any extras of these?. Since the Subbu V3 dac will be released first single ended and later balanced, I have elected to build both and I will need one more filter. In fact if you can offer it with parts I would buy it that way to simplify things.
Bill
