The simplistic Salas low voltage shunt regulator
First is a dense noise like pattern though when the other is some shape. It may gets its peaks mixed in the noise too. But the amplitudes are very different still. Is there some clock related frequency that explains circa 5MHZ possible emission on the Shiga? Harmonically related up or down a crystal fundamental even?
Yep that s them.
Thanks a lot for the quick after-hours helpdesk 🙂
The crystal is at ~16Mhz if I remember correctly.
However I was getting something similar with the plain 7808 psu before separating the digital parts from the motors. It was about same size, but bit different freq
I found the capture... Don t know if it s related...
Its not that far in freq, the other is broken in shape and it could be counting somewhat off. There is no way a 7808 can be producing anything in the 6-7MHZ. Emissions from the digital stuff and the way they couple most likely.
At the time I was suspecting the FRs with their low ESR making the 7808 ring...
By the way the cap at the sense seems to have made things worse
attachment.php
The 5Mhz seem to dissapear some times though... it seems to depend a lot on how I attach the probe...
