I will try the AD797BR, lots of a good reviews for it.
But it's a single opamp so I will put them on a single to dual adapter like this one.
Thank you ! 🙂 Then I will use 4 x AD 8620
Oh I forgot it can only be used up to 12 V .
These op-amp work at a max voltage 2 x 13V and the original shunt is set to 2 x 15V so if you want to use these op-amp ask to Qhangao for a change on your shunt.
What is the function of the vertical pin header on the I/V stage opamp?
There are pin headers only to separate the power supply
Here some photos received today from Quanghao
The persons on this group buy can buy directly the USB-I2S module from Amanero Technologies at the special price of 49$ (39 euro).
Interesting offer for the amanero. Andrea, could you pls inform how to ask for that discount ?
Simple, tell to Amanero that you are in the DAC group buy of Quanghao
Hello
Just to make this clear (for me). Should we order the Amanero direct from Amanero tech. incl the GB discount and will the amanero be canceled from the GB orderlist?
Anyway.. Thank you so much for making this discount available.
Br
Caad
Hello
Br
Caad
Yes I wonder to 🙂
Welcome to you!
I sincerely apologize to you for the absence and my delay!
We look forward to your understanding and I look forward to your ignore these errors and my faults!
All my kit was perfect dac finished welding machine and welding arms, now I'm all checked and correct the error, the next few days, I began to test each of the!
Therefore, the time may be slower than expected, optical understanding your pride and ask for more time optical proud.
Meanwhile chassi power transformers and will come to my house.
Thank you!
quanghao
Thank you!
quanghao
Hi, is this Crystek 602673?
Thank you
I bought 46: CCHD-549-950-25-100, and Mouser paid but did not receive confirmation of my money, now keeps crashing.
So I have to ask someone else to buy: CCHD-549-575-50-100, to replace it.
It is a forced choice situation, now I have to get a refund were quickly:
549-CCHD-950-25-100.
please the you understand for me
quanghao
Hi quanghao,
Welcome to you too.
Regarding the Amanero discounted at 49USD, I'd like to change my mind and add this interface to my kit (dac base+chassis).
Also please notice that "raoul" (my surname) and "rliyung" (my nickname) is the same person.
Regards.
raoul from France
Welcome to you too.
Regards.
raoul from France
quanghao
Ok thank you .it was just get information about items.
what is your suggestion to use high end models and brands instead of it ?
I saw also this atomic oscillators .Maybe it can't be useful for this project but it can be next .
Chip Scale Atomic Clock (CSAC) - Symmetricom
Digital Audio Blog: Antelope Isochrone 10M Rubidium Atomic Clock
Hi quanghao,
As we can now purchase the Amanero board directly at discounted price, Can I cancel my order of the Amanero board from you?
halook
halook
quanghao
Hi Quanghao.
The CCHD-549-575-50-100 is an exellent equivalent to CCHD-549-950-25-100. It has an outstanding specification concerning to Phase Noise (=Low jitter).
Br
Caad
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
