Switchable Hi-Z input impedance, how ?
Tin,
you are still showing the BJT buffer without a DC blocking cap on the input.
Without that necessary cap, anything you attach to the front end will corrupt the BJT biasing you have shown.
Look again at that 2002 pre-amp.
C1, C4, C7, C16, C17, C8, C14, C18, C19, C20 are all DC blocking caps.
Tin,
yah, I know....but right now Im working on the jfet section only
you may notice I removed output resistors
so the jfet output dc blocking cap would connect directly to the BJT buffer
but that BJT thing is just for fun
output buffer for the final preamp project will different, and have symmetric power supply
unfortunately no time for that right now
but until then I need to stay fit, and on my toes 😀
like said, it works fine again
and I like the parallel pickups too
but had to change tone control cap
or else it was way too bright
found a wire had been jammed by magnet
and I broke one coil wire
I suppose it burned from too many solderings, when testing the different configurations
not all worked well
(as a warning if you try this)
Hi Tinitus, yes those really small wires can be tricky. I avoid touching them if at all possible. If I do I rewire the other end of the cable connections with a switch. In my case it's a 5 way switch for strat style 3 pup. While you have the pickups out you may want to look at the shielding inside the cavity of the bass. Get some copper tape and line the insides, as well as the cover, and connect to your jack ground. Should be a big improvement to reducing hum and interference.
